Results 1 to 8 of 8
    Very Active Member PCBeachBum's Avatar
    Nov 2009
    Panama City Beach, FL
    Default A neat little tip
    Why you should always put a coin in the freezer before you leave home.
    Have you ever come home from vacation, business trip or maybe a weekend away with the family, and noticed your digital
    clocks flashing the wrong time?
    You quickly realize that you had a power outage while you were away, but it's basically impossible to tell when it occurred or
    how long it lasted. It's therefore also impossible to tell just how long the food in your freezer may have thawed and then frozen again.
    In connection with Hurricane Matthews, which recently swept over parts of the eastern United States, a woman named Sheila Pulanco
    Russell shared a clever trick on her Facebook wall with anyone who was forced to evacuate their home.
    But the trick is certainly also good to know in case of any prolonged departure from your home, and will ease your mind about whether
    or not the food in your freezer is good to eat, or best be thrown-out.
    The trick lies in the combination of three simple but effective tools everyone has at home: a mug, a coin and some tap water.
    In a Facebook post which quickly received hundreds of thousands of reactions and shares, Sheila explained how to proceed. She wrote:
    "For those of you that are evacuating from the coast, I just heard a great tip. It's called the one cup tip. You put a cup of water in your freezer.
    Freeze it solid, then put a quarter on top of it and leave it in your freezer. That way, when you come back after you've been evacuated, you
    can tell if your food went completely bad and just refroze, or if it stayed frozen while you were gone.
    If the quarter has fallen to the bottom of the cup, that means all the food defrosted and you should throw it out. But if the quarter is either on
    the top or in the middle of the cup, your food may still be okay. It would be a great idea to leave this in your freezer all the time. Then, if you
    lose power for any reason, you will have this tip to fall back on.
    If you don't feel good about your food, just throw it out. The main thing is for all to be safe.
    Simple, effective - and definitely a money saver, because you don't have to toss loads of food unnecessarily.
    Please share this nifty trick with all your friends!
    Happy Spyder Owner
    2008 SM5, Trunk Liner, 2" Block Riser, ESI 3" Risers, Evoluzione Cycle o2 Sensor Mod, Corbin Seat and Large Oval Backrest, Madstad RoboBrackets and 24" Clear Windshield, Chrome Clear Catseye LED Tail/Brake/License Plate Light, Brake Strobe, Kuryakyn Grips, Kewlmetals Performance Air kit, Custom Dynamic Orange LED's, Spyder 1 Attitude Performance Exhaust RSS-18-B, Day Runners, Day Pucks, Rivco Highway Pegs, ESI Mirror Extensions, Rivco Floorboards.
    Default Good to know...
    Smart way to check up and not finally thaw out your favorite food only to find it is spoiled...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Thanks for the information.
    Jun 2014
    ny
    clever idea
    Active Member drhunt204's Avatar
    May 2016
    S.E. Missouri
    Nice idea, thanks for sharing this with us.
    Jun 2015
    St Charles, IL
    If you have popcicles in your freezer, you can use them as a indicator also or at least that's why I claim that I need to have them.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    This tip may be useful if you check the cup periodically. Ice in a freezer will slowly sublimate, which is the effect of changing directly from solid to gas. So, the ice will slowly disappear and you will need to refill the cup. If not, you will eventually have a coin sitting at the bottom of an empty cup.
