I have a tank bag that I used on my Sportster and it was very useful. However, the bag mounts magnetically, so I guess you can see the problem with mounting it on my F3. I am assuming that I could sew some straps to the bottom and run them underneath then use velcro to connect the straps to the bottom of the bag. Before I go to far with this idea, I am wondering what others may have done. The bag is almost brand new, so I don't want to scrap it and buy another one. Any thoughts?
Thanks!
There comes a time in life when you really want to stay in the wind, but single-track vehicles are no longer a practical or safe solution. The Can AM Spyder is a wonderful answer to a difficult situation.
Most tank bags already have "D" rings sewn in place, use them & some camping straps & or some Velcro straps.
Can also add some quick detach clips to either end
If not happy with placement, you might find a good trade with some one in opposite situation
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
One strap up front around the lower part of the steering head; another up the back dropping down between the seat & the glovebox/pie warmer then around the main frame spar, & voila, there's a tank bag on an RT that you can fit all sorts of things into, so I'm sure you could readily do something similar on an F3!
THAT'S WHAT I DID.....
i added a length of 1" nylon straps to the existing straps, and looped it down under the gas tank... works fine... 20170221_183841.jpg20170221_183913.jpg
Dan P
SPYD3R
Since the bag is designed to be attached magnetically, there are no "D" rings present. Whatever I attach will be sewn or attached with velcro. Finding somebody willing to trade is a great idea but not likely. Anybody out there that wants to do that?
