Bluetooth transmitter with Sena 20s
Anyone have any advice with using an independent Bluetooth transmitter to their Sena 20s. I would like to remove my Sirius from the sm10 transmitter and put it on its own unit, the present connection is very intermittent and choppy. For the price of these new units it is less expensive than redoing the sm10 install and opens up some other options as well.
2014 RT-S Pearl White
Try lamonster garage
He shows a very inexpensive way to install a Bluetooth. I have the sena 20 so far does everything well I bint purchase any oem add ons I installed my own sat. And gps they work very well only part is my gps can't be heard through my helmet but I can live with that sat radio works would recommend fm direct adaptor to block signals you should be good
Does your Sirius have an FM transmitter? You could use the FM on the 20s to pick it up.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Good thoughjt, I might have to try that.
I forgot all about the FM option.
