219400584 gps mount harness (incomplete)
I bought this kit and only used the handlebar piece for the ram mount. Selling the wiring harness for gps, not sure if it is worth anything to anyone. The whole kit was like $175 or so. I guess I'll start out asking $75 shipped obo. If my price is off or if it's worth nothing without the mount someone let me know.
Should I assume this is worthless?
Not necessarily. I can't tell what is included in the kit. The harness is usually integrated with the GPS mount itself, so maybe you didn't mean what you said about it?
Which GPS is it for? Is there a BRP part number on the box? If so, we can look it up online.
What is excluded from the kit? The RAM handlebar mount or what exactly?
Thanks.
2014 RTL Platinum
Thanks.
I put the part number in the header. The only pieces removed is the ram handlebar mount and the piece that connects two ram balls together, everything else is there untouched.
So you did. Thanks. Is there anything that would tell you which Garmin GPS the mount / harness is made for?
2014 RTL Platinum
Can't tell what is in the box. . .
Judging by the Can-Am Accessories page, I presume the remaining piece is only the top RAM piece that the cradle attaches to. OR is the cradle included also? Unfortunately, the above referenced page doesn't list exactly what is in the box. There are approximately 7 different devices the cradle could fit. I would recommend a photo(s) of everything remaining completely laid out & visible. $10, incl shipping?
The cradle says garmin on back zumo on front, guessing that the make/model of gps it holds. Here is a pic of everything in the box.
That is the Garmin Zumo 590 wire harness/cradle for the Spyders. The wire harness is made to plug and play for the RT and F3T/L
It would be worth $75 dollars for someone who bought the Zumo 590 elsewhere beside from BRP.
www.sasspyders.com
2016 F3T
2015 Freedom Trailer
Sypderpops BumpSkid Plate
Lamonster ISP Key Cover
Lamonster F3 Bar Clamp and Power Port
Lamonster RIP floorboards and frame caps
Lamonster Chevron Highway Pegs
BajaRon Swaybar & Heim Links
F4 Custom 21" tinted windshield
BRP Cannonball Seat
BRP F3 Idler Pully
FOBO TPMS
LidLox (dual)
Garmin 660LM GPS
Cat Delete Performance Pipe
F3T Top Case
PPA Black Widow Wheels
Custom Frunk Wrap
Okay, then what you have left is basically this which I recently bought on Amazon for $52 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. So, yes, it has value for someone looking to relocate their gps from the OEM mount while retaining the OEM mount.
I believe it's for the Zumo 590.
Reason: correction
2014 RTL Platinum
I agree. See my other post.
2014 RTL Platinum
