ecu flash
Does anybody know what's the different's are between Monster FI (Steve) and ECU xtreme (Jason) ecu flash's apart from the price.???
Ozzie Ozzie Ozzie
Sent you a PM Duncan, but you can take it as read from me, that I am extremely happy with my Spyder now & as a result recommend the 'ECU Xtreme' (Jase) reflash over anything else!
Contact info
Does anyone have contact info on Jason for info on his services?
Ozzie Ozzie Ozzie
He can be contacted at ECU Xtreme, which is on the Gold Coast in Aust, via email to:
rotaxracing@gmail.com
I have just taken my upgraded ECU for a run. It was really fast....I struggled to run along side it, so I decided to put it back in the F3.
I have to say that I am very impressed with the ECU Xtreme upgrade. I wasn’t expecting too much difference as I was just getting a Stage 1 tune (Peter Aawen has a Stage 546 supercharged turbo tune). I was quite surprised. The throttle response is now immediate and very, very smooth at all rev ranges and gears.
I used to have a particular issue with freeway on ramps where the semi auto would kick down to 3rd gear as I slowed on approach, but as soon as I opened the throttle to get up to freeway speed to merge, it would bog down, and I would have to toggle to 2nd, and with an approaching b-double, every second is crucial. Today I deliberately made sure it was in 3rd, hit the throttle, and had travelled 500 metres before the F3 touched down again....... well that may be a slight exaggeration, but suffice to say that I did not feel any need to change down to 2nd. Apparently, Jase put the Stage 2 tune in my F3, but set reasonable red line limits for me.
For me, the cost is well worth it, just for the grin it brings to my ugly mug. It is right up there with Ron’s stabiliser bar and my DayLong seat as one of the most justifiable mods I have done.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
anyone in US that can flash it with reasonable turnaround?
6 states down 42 states to go
ECU - FLASH
Monster Fuel Injection ( whose base is in Canada ) has two US companies that work with/for " Monster " and will be able to do the Flash for you ..... one is in Louisiana and the other might be in N.C. .... do an Advance search above ..... Mike
ECU - FLASH
thank you. So the place in Louisiana would have exact same software as Monster FI in Canada?
I am not too familiar with what goes into flashing an ecu but it sure does sound like its something better than just fuel management.
https://monsterfuelinjection.com/usa-outlet/
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Has anyone.......
Has any one ever Dyno tested an OEM 1330 for a base line reading on HP and acceleration, and then dyno'ed it again with the cat delete pipe, with and w/o the BC thunder baffle to make a valid comparison? From some conversations here the cat delete process may actually be hindering performance and only providing a louder exhaust noise.
I have a 2013 RSS that specs out to 100HP @ 7500RPM. It sounds like the Monster FI ECU upgrade should boost that to 125HP and maybe more since I have the Two Brothers exhaust system. I would be very interested in any opinions if this assumption is correct. If so, then $400 does seem like quite a bargain.
I had my 2015 RT Limited reflashed by Wick It in Louisiana, and it was worth every penny. There is no throttle lag, and the power is there from the time you twist the throttle. It makes it much nicer across the power band, and over 6,000 rpm will really get your attention.
By the way, it took a week from the time I sent my ECU to them, until I had it back and installed.
Yeah, I couldn’t care less about data showing an extra few horses on the dyno, Devious. I personally don’t need to wave a graph around to show that I’ve got more torque than someone else. It’s all about the grin you get when you ride, and it sounds like you’ve got that....and Jase’s flash (the permanent one that can’t be overwritten by BRP at service time, by the way) has given me that grin in spades. My results are exactly the same as yours, and I love, love, love it.
HeliBars Handlebars
Kenda Kanine rear.
