Results 1 to 4 of 4
    May 2017
    Ohio
    Default Am I missing a vacuum line, pic included
    there is an electronic device with a couple hoses and an electrical connector, that has an exposed port facing forward, is there a hose missing off of it? Right side of bike, beside the top left corner of the radiator.
    thanks, luke
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Bad-Day View Post
    thanks, luke
    If you have a Manual Clutch transmission, that would be your vacuum assist solenoid for your clutch. And if so, you're good. That's the vent to atmosphere port.
    If not, then you better give us more info on your machine.
    Doug
    ”Freedom is not a loophole”
    May 2017
    Ohio
    Yes it is a manual transmission, so I am good??? just seemed odd when I saw it. Thanks.. Luke
    Nov 2015
    Chardon, OH
    You're not the first to think it odd. BRP should have put a little rubber fitting with a foam filter on it. Probably not necessary but it would look finished. Ride safe.
    Doug
