Results 1 to 3 of 3
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    Default Where should I tap into to get switched power for the FZ-1 Fuzeblock?
    I installed the fuze block on the right side behind the panel, just below the right mirror. I ran the constant power and ground lines straight to the battery. Works great. Where should I run the switched line to? I don't want to upset the can bus system.
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default Used used this
    Hi when I did mine I tapped into the switched wire for the gas gauge as the gauge was no longer there. It works great!
    14 RT-S , Stock Large brake pedal White Pearl
    May 2017
    I still have my gages there, but people say the digital display is more accurate, so I might disconnect them. Until I do, would it mess anything up to tie into the switched positive on either the temp or fuel gage?
