Results 1 to 8 of 8
    Jul 2017
    Woodbine, Iowa
    Default Phone Handle Bar Mount
    I have my phone on my glove box which makes it hard to read. Is there anyone making a handle bar phone mount? I have the Can Am Spyder RT. I have not found one.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Try these guys
    Google RAM mounts. If you get the dash mount from JT company ( a sponsor here), you can use a RAM ball ( with 1/4 -20 stud) a short or long arm and a phone holder { x-grip). It will be up high so you don't have to take you eyes off the road. There is even a rubber "web" to guarantee the phone won't fall out.
    If you don't want the dash mount there is a claw mount and a bar mount also. They have scores of different mounting systems.
    Kaos
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    Default Techmount & Techgripper
    It WON'T fall out.
    Linden, CA
    Check with Lamont
    Lamonster Garage and others have them .
    Quote Originally Posted by gerald37 View Post
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    I have one of these, attached it to a screw on the upper right dash. Works great.
    https://www.amazon.com/dp/B017UC20QC/_encoding=UTF8?coliid=I2550XDUK1LT97&colid=3L1O9FO HY8PF4
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Registered Users classicvw's Avatar
    Aug 2017
    New Jersey
    Don't know if you found something yet, but interphone.com has phone and gps mounts for irregular shaped handlebars. It's kind of a wide removable zip tie method. Works well.
    Oct 2016
    Faribault, MN
    Default Over Dash Phone mount
    I had issues with the xyz phone mount vibrating loose, changed to TACFORM's holder and have done 20K plus miles with no issue. I have my phone mounted over the dash edge facing right at me (landscape mode), using a JT's Dashbar, Ram Mount Double Socket Swivel Arm, and now a TACForm.com phone grip. I also brought usb power to the top of the dash from the battery on my '13 RT. Works GREAT!
    Changed to the TacForm Holder and never fiddled with it again.
    Last edited by DGoebel; 05-23-2022 at 11:29 AM. Reason: Added TACFORM Holder vs IPOW
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    I use the Tricled dash mount with Ram mount. Like it.
