Results 1 to 11 of 11
    Nov 2015
    Cypress
    Default F3T front grill removal
    Anyone had a chance to remove the front grill in the F3T. I am thinking about doing some mods and thought it would be easier if the grill was removed. Hopefully it will be a few easily accessed screws and out it comes?
    Buckskin
    2016 F3T , Pearl White
    Nov 2012
    North Las Vegas, NV
    I did it a while back to clean the radiators after we followed a hay wagon. I think it was 4 screws.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2015
    Cypress
    That's what I was hoping. Will take a flashlight and look around for the fasteners and see if that gets them all.
    Buckskin
    Active Member Colin's Avatar
    May 2011
    Karaka NZ
    Yep. only 4 screws, and it is easy to get on and off, I have done it a few times, amazing how many bugs etc get in there.
    I put some LEDs in there and they provide a subtle light through the grill, I was hoping to paint the mesh behind the grill
    blue as well, but patience isn't my strongest virtue a lot of clips attached to plastic lugs to hold it on, I know for sure I
    would break at least one hahaha
    We now have His and Hers Spyders.
    Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
    Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
    Previous Spyders
    2013 ST SM5
    2011 RSS
    2010 RS
    2015 F3 , Black with Blue Graphics
    May 2009
    Connecticut
    If you jack up the front about 7 inches you can sit in a armless office chair and remove them. The first time I was laying on the floor- Not great at 68?
    The front fascia has 6 screws -4 in front and a push pin on bottom- 2 around the lower back sides that are a pain to get to?
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member Samson's Avatar
    Aug 2016
    Prescott Valley , Az
    Very easy, I removed mine at the 3000 mile service to clean and hose the radiators out. Was very clean, not bad all.
    Jul 2014
    United States
    Aug 2013
    Northern California
    Default Ano wrench here
    It was so easy I could do it........and put it back on!
    Nov 2015
    Cypress
    Very nice Doc! Mines a '16 F3T, but most likely it's the same.
    Buckskin
    Quote Originally Posted by Doc Humphreys View Post
    Jul 2014
    United States
    I really like the new setup. Since the radiators are turned sideways they don't pick up as much stuff from the road and are easier to blow through with compressed air from the outside with the grill off. Good bit of engineering there, BRP!
    MOgang Member & Pyro-Man kevorama's Avatar
    Jan 2012
    Troy, MO.
    Default F3T Grill Won't fit back into the body tabs
    The grill comes off real easy. I put some LED lighting in the back of that area and I cannot get the grill top tabs into those 4 body panel slots to save my life. The screw holes line up just fine. But, with the tabs not in the slots there is a ton of light leakage coming through the top of the grill and the body panel. Has anyone else had this issue? Ive been working on putting this back together for the last few hours. I'm at a loss.
    “Dream as if you'll live forever, live as if you'll die tomorrow.”
    James Dean
