Results 1 to 4 of 4
    May 2017
    Central Texas
    Default Radio Frequency Noise form Headlights
    2009 GS/RS SE5. I just installed a J&M CB radio, that also attaches to 3.5 input to listen to tunes, books, etc. The line in is in a dash pouch that sits under the windscreen. My wife states she can't hear the radio, or music due to incredible RF noise. When she pulls along side me, I hear the same noise on my bike, through my system. I did install the J&M Static filter, so I was surprised she gets this noise. Aren't the OEM headlights HIDs? Does anyone else have heavy static noise in the phone or MP3 player when set up on the dash?
    I was planning on replacing the headlights with some LED's, but I heard their transformers will cause RF noise also.
    Whats a guy to do? Try incandescent H7s?
    Active Member Bandera's Avatar
    Bandera, Tx
    Default J&M CB Radio
    I am not familiar with the radio, but I would recommend the following:
    • Check to ensure all connections to the radio are tight.
    • Use a shielded cable between the external ipod type device to the CB unit
    • make sure the headlight connectors are fully seated and clean the connection if necessary.
    • lastly, you may need to add toroid beads or cores to the ends of some of the cabling to help reduce RFI into the CB
    Regards
    Michael
    W5MWI
    USN Vet - RM1
    Member: VFW & American Legion
    2020 Spyder RT-L - Jupiter Metallic Blue Chrome
    Jul 2011
    Mitchell, Ontario, Canada
    The OEM headlights are not HIDs. They are regular halogen bulbs. If it does have HIDs. Could a previous owner installed a inferior quality set?
    2018 F3 LIMITED
    Danbury Connecticut
    That would be my guess.
    IBA #47122
    2020 RT Limited Asphalt Grey
