Results 1 to 14 of 14
    Apr 2017
    hinckley,mora Mn
    Default auxiliary switch?
    is there a auxiliary position on the can am spyder 2015 rts so you can charge your gadgets when having lunch or what ever. can't seem to find it in the manual.
    Aug 2016
    Central Illinois
    Default switch
    If you switch a fuse in the frunk it will leave the cigar plug adaptor in the trunk hot all the time. I have a 16 RTS and behind the lining in the frunk there is a plug with wires that you can tap into to put another switch in the frunk. Others have run a hot wire up and placed an adapter in the radio grill plate and someone has a neat one they put in on the rocker panel. I think if you search for power outlet or USB install some will pop up.
    Enjoy the ryde.
    Ranman42
    Default CHARGING WHILE OFF
    Quote Originally Posted by Dickthal View Post
    If you think this absolutely necessary ...... imho get one of those small ion battery jump starters .... in case you deplete your OEM battery ...... Mike
    Apr 2017
    North Central Florida
    My '11 RT had two 12 V outlets, one front and one back.
    At least one of them was HOT all the time.
    I haven't had a chance to check the new '17 one yet......because I don't get to pick it up for another week.
    But as was mentioned, I'm not sure that charging gadgets from the Spyder while it is not running is a really good idea.
    Jan 2015
    southern WI
    As mentioned, you can swap a fuse in the fuse box in the frunk to make your 12 plug in the trunk hot all the time. I also added a 12 volt plug to the frunk by utilizing the wires behind the liner in the frunk. Very easy to do. If you're just charging stuff with USB or 12v plugs while ya grab a bite to eat, you'll be fine. I also added a dual usb in my speaker grill, as mentioned above. Just ran a wire from the battery up to the speaker grill area. I have 4 points of power if I need them, 3 12v plugs, and a dual usb. My wife uses the trunk power while we ride, and I use the ports in the speaker grills for phone and/or gps
    2021 RT Limited
    2016 RTS , Pearl White
    Apr 2017
    Quote Originally Posted by Mazo EMS2 View Post
    Don't you really mean that you can move a wire to a different fuse position ??
    Jul 2014
    Mint Hill, NC
    Page 60 of your owner's manual.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jan 2015
    southern WI
    Quote Originally Posted by Easy Rider View Post
    It explains in the manual about moving fuses in the, (I believe) #7 and #8 positions to make the trunk power outlet hot all the time.
    2021 RT Limited
    Apr 2017
    What them Canadians won't think of next.
    Would that be the owners manual or the shop manual ??
    Jul 2014
    Mint Hill, NC
    See post #7.
    Cognac 2014 RT-S
    Active Member willey's Avatar
    Jul 2013
    martinsburg,ohio
    Default cell phones
    My phone never runs down.When I unplug the tender I shut my phone off , throw it in the frunk and that is where it lives while i'am on the rode.Its good to have it if I need it but I never have to charge it during the day.
    The Owners Manual...
    A 12-volt electric appliance may be
    connected to the jack connector. Electric
    current is supplied all the time.
    NOTICE The 12-volt power outlet
    is not designed to supply current of
    more than 3 amperes.
    NOTE: Leaving an appliance connected
    while the engine is not running
    will gradually discharge the battery.
    NOTE: When fuse 6 is installed in the
    RH fuse box, 12 V power outlet is only
    operational when ignition switch is at
    ON position. When fuse 7 is installed,
    12 V power outlet is always operational.
    Using
    Apr 2017
    hinckley,mora Mn
    Default Auxiliary switch
    Thanks again for the help,and I thought I read the manual, sure enough Page 60, kinda like reading the Bible ,ya miss a lot sometimes.
