Results 1 to 10 of 10
Thread: First ride
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Default First ride
    Finally after buying my first used 2015 Spyder RTL I got out on a ride yesterday afternoon. Sqeeling brakes is that normal for a bike that was sitting at a dealership for a couple of months. Will this go away after riding for a while.
    Mar 2015
    NE Kansas
    Congratulations on your new bike and first ride! Every ride will get better and more enjoyable as you learn how your bike responds to you and you to it. The brakes may be a bit dusty and thus squealing.
    Default BRAKE SQUEEL
    This is ONLY common when you stop or slow in reverse.... going forward they shouldn't ... you can get some spray products that will have some effect .... but as the other poster said , if it was not used for a long period it may need cleaning .... using them will do that .... but if it persists take it back ...... Mike
    Apr 2012
    Northglenn Colorado
    My F3 brakes have always Sqeeled a little. Dealer said it was in normal range. Some here have said to spray with wheel/brake cleaner and the noise will go away. I have not remembered to purchase so I don't know if it actually helps.
    and...what they said about the brakes.
    Default Try this....
    Make a few straight line emergency stops at about 60 mph. This should heat them up and clean them and the disc off. If from brake dust some simple green sprayed on and hosed off will get the dust off...
    ​2012 RS sm5
    Active Member willey's Avatar
    Jul 2013
    martinsburg,ohio
    Default breaks
    ride about 20 or 30 yds in reverse gentling riding your brake pedal.this has allways worked for me.
    Jun 2017
    Hanover Ont Canada
    Default Led lights
    Some of the led lights are burnt out on my left fender rear facing red lights. Do I have to change the whole piece or not likely can I just change the little bulbs if that is what they are. I have no idea because I just bought this bike, and I am new to all of this stuff.
    Sep 2013
    Cambridge, Ontaio
    Congratulations on getting your Spyder. Check out Ontario Spyder Ryders on Facebook. Lots of info and the occasional ride. Check out Stanley's BBQ. You will meet plenty of riders in the area.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Rookiespyder View Post
    LED lights are actually solid state devices soldered to a circuit board of some type. They should outlast you in normal use, which is why they don't make them repairable. Most of the vendors on this forum that provide LED products will provide a warranty, so it would help if you had the paperwork from the prior owner to show who provided / installed them.
    Otherwise, you can either live with having one or two diodes burned out, or you can replace the whole fixture. Not too many other options.
    BTW, LED's are not unique to Spyders, but the after-market products on your bike are in most cases designed specifically for the Spyder. Time to do a little research and maybe post a picture for us to better understand what you're dealing with.
    2014 RTL Platinum
