Results 1 to 8 of 8
Thread: Peesh peesh
    Jun 2017
    Hanover Ont Canada
    Default Peesh peesh
    Can anyone tell me why my 2015 Spyder RTL makes a like peesh peesh noise when I back up. Could it be my rear shock making that noise or could it be something else. I just purchased the bike a week ago from a dealership. I took it for my first ride today had to wait to pass the course first before I could get insurance on it. They are a awesome machine.
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default Mine too
    My 2016 does that too, I'm no professional. I just assumed it was the Air suspension.
    Quote Originally Posted by Rookiespyder View Post
    May 2013
    Stanton, ca
    Probably the air ride letting out air.
    The air bag ride is not adjusted (pumped up or letting out air) until you put it in gear.
    So chances are your putting it in reverse as the first gear you put it in after starting.
    Bob
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    It is the air suspension making adjustments. Will happen as well when riding two up and the passenger falls off.
    Apr 2017
    Hamilton, Ontario, Canada
    Mine is more of a pish push sound - accompanied by a loud scream when my wife fell off 😂
    Default THAT SOUND
    It appears that most if not all Spyders exhibit Brake squeal when backing up ..... could it be this ???? ... Mike
    Bossier LoUiSiAna
    Even my ST has made a similar sound. Have to go double check now but I thought was more of the belt adjusting on the sprocket than sound of air not quite rubbing but very similar & only on belt side when moving.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Geez, before a panic starts about belts and brakes -- put a passenger on the back and take them for a short ride. If you hear the sound after they get off it's the air suspension releasing pressure no longer needed due to the lack of a passenger.
