Engine Stop Switch -- Really?
After picking up my new Spyder this afternoon, I've been pouring thru the manual.
I see that it recommends turning off the engine by using the "Engine Stop Switch" rather than simply turning the key and removing it (like you would with a car). I guess my question is whether that extra step (turning off that switch, then having to turn it back on when re-starting the Spyder) is really necessary? Do all of you experienced Spyder Ryders use than switch (on/off) each and every time?
Thanks!
Yes, you should use the engine cutoff switch every time you shut your Spyder off. That way in an emergency you won't be searching for it. I was riding down the freeway when my bike went up in flames, the first thing I did was hit the emergency flashers followed by the engine cutoff switch. Also, if you were in an emergency and wanted to quickly shut down the bike if you used the key that would require removing your hand from the handlebars and that could be a bad idea.
Have you taken a motorcycle safety course? If not, you should really think about it as the Spyder is more like a motorcycle than you may think.
Enjoy your new ride.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I admit
that I do not use the kill switch, but use the key. I have never read the reason for using the kill switch this way, and now I think I need to start using it to turn off the Spyder. Thank you.
Is it Friday yet? ... Oh yeah, I forgot. I'm retired
Past bikes
2010 RS - Sold
2012 RT - Sold
2014 RT - Testing completed
2016 F3-T Audio package - Sold
That makes sense. Duh.
2014 RTL Platinum
I remember there being a thread on here a while back about the kill switch. Some people were quite set on not using the kill switch because it is not necessary to do.
Of course it isn't necessary to use but it's a good idea to become familiar with it. Regardless if you use it or not, it's a good idea to check it before starting your trike.
When I had the motorcycle safety course they said to turn off the bike with the kill switch & then turn off the key.
I'm sure there are quite a few people out there that have had problems starting their ride because someone flip the kill switch & they never got into the habit of checking it.
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Hahaha......yep......that would be ME, Steve.
So to save me getting my manual out, it's a case of Park Brake On, hit Kill Switch, turn Ignition Key off ?
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Yep. Don't forget to pocket the key too. Starting is insert key, kill switch, foot on brake, turn key on, wait for the gauges to start their sweep, push the mode button and then the start button. It's the Canadian version of a Chinese puzzle. I've found pushing the mode button before the gauges sweep doesn't work. Happy Ryding!
BajaRon Sway Bar
Foam Grips
Shorty antenna
Yep.....that's the way I shut down my Indian
I discovered that my "dismount" technique on the Spyder causes my gut to bump the kill switch to OFF.
It is a tradeoff. Most of the people who have trouble with the switch are the ones who USE it all the time; it wears out.
Thanks for your thoughts on this, guys. I'll have to get into the habit of using it.
Originally Posted by newbert
After picking up my new Spyder this afternoon, I've been pouring thru the manual. I see that it recommends turning off the engine by using the "Engine Stop Switch" rather than simply turning the key and removing it (like you would with a car). I guess my question is whether that extra step (turning off that switch, then having to turn it back on when re-starting the Spyder) is really necessary? Do all of you experienced Spyder Ryders use than switch (on/off) each and every time?
Thanks for bringing that to my attention. I have not been doing that. Earlier on this forum there was a flurry of posts about failed switches so I wonder if that's Can-Am's way of ensuring it gets cycled often enough to keep it working? I guess I'm willing to give the engineers the benefit of the doubt.
2014 RTL Platinum
Good idea...
If you get in the habit of usingvthe kill switch it becomes second nature and a sure safe way the shut down the machine especially in an emergency...
I prefer the kill switch over the MODE button
Meh... 100,000+ miles between my 3 spyders and never a kill switch failure. You probably have a better chance of failure due to non-use and corrosion than you do from over-use.
Thanks!
ive a faulty stop switch , is it servicable ?? ie presure on .. bike starts release pressure .. stops...
