Results 1 to 7 of 7
Thread: Oil Leak
    Sep 2015
    lumberton,tx
    Default Oil Leak
    I have a 2014 RTL. Ever since my last oil change, about 6 or 7 mos. ago, after a ride I will get several drips of oil on the floor under the right side of the engine. After a few times I determined that the oil level was a little high and I drew off enough to get the level to the halfway mark between full and add on the dipstick. I followed the manual precisely to check the level. Even after removing the excess I still get the drips. There is no oil showing around the dipstick housing, the oil filter housing or around the oil plug. If I damaged one of the o-rings putting the plug back in, could this cause the leak? Or does someone have another idea?
    Thanks,
    Ron
    Default LEAK
    The 1330 has two plugs .... look at the other one ...... Mike
    Sep 2009
    La Valle, WI
    I would check the oil filter housing. The seal may be leaking. You'll have to remove mirror and side panel to see.
    2018 F3 Limited , Oxford Blue
    Member Maddoggie501's Avatar
    Jun 2017
    Albuquerque, NM
    Quote Originally Posted by JP58 View Post
    FWIW, If you can get under her. Check the pan under the engine. I understand when the oil is changed some oil will end up in the pan and drip for months. Others have made the oil drain plug hole in the pan a bit larger so this doesn't occur. Just worth checking into.
    Jun 2017
    Albuquerque, NM
    Default Little checking..
    After you check all and including above suggestions...there was an issue with one of the engine cover bolts on the 14's. I believe right side rear cover on the engine. Also if you were running too much oil could be leaking from the airbox....
    ​2012 RS sm5
    Sep 2015
    lumberton,tx
    Forgot to mention that I pulled the air filter and no sign of oil. Also, when I did the oil change it was my first and I pulled the lower pan so I could see better.
