Page 1 of 3 123 LastLast
Results 1 to 25 of 67
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Question What Mileage Are you Changing Your Oil?
    Have 3,200 miles on the oil change done by the dealer. I have to admit, always changed oil at 3,000 miles be it car or bike. With synthetic, let my wife's car go to 6,000 miles.
    I am not willing to let the BRP oil go as long as the manual recommends, especially since it is a synthetic blend, not full synthetic. I plan on using this oil https://www.amazon.com/Castrol-Power...ct_top?ie=UTF8
    Have used Castrol my whole life and not about to change. For those with the BRP oil, how many miles are you going between changes?
    For those using synthetic (any brand) how long are you going between changes?
    Do not want this to turn into an oil thread, just want to know what mileage you all feel comfortable with changing the oil at. I know a few of you have had oil testing done and that information would be helpful with determining when to change.
    Thank You, Louie and Meg
    2015 RTL , Red
    Default Well....
    I use the XPS synthetic blend and it has done well. I used Castrol before on all my bikes this is just as good. I always change my oil and filter 3,000 to 5,000 depending on the ryding I have been doing...
    ​2012 RS sm5
    Aug 2013
    Northern California
    Default 2015
    Looks like you have a 2015 RTL. If that is correct, your owners manual says every 9300 miles....yes I know that seems like a long time, but that will keep your warranty in good standing and seems to not cause any issues. Chupaca has the 998 engine and that is more of the 3000 miles recommendation. The maintenance schedule on the 1330 engine with the SE6 is really nice on the pocket book!
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default SERVICE
    i had my F3-S serviced today @ 37,294 miles of smiles.... this is my 5th oil change... i don't go the 9300+ miles, but come close once:
    1st 3109 miles
    2nd 11,880
    3rd 20,280
    4th 29,289
    5th 37,294
    i use ONLY the BRP oil, and i've yet to have any issues with lubrication...
    Dan P
    SPYD3R
    Aug 2007
    Greeneville, TN
    Have your oil tested. The report may shock you. Especially on the 1330's.
    Mar 2013
    I started out changing every 5000 miles and having the oil tested and always the reports would tell me to go longer before changing. When we road to Alaska the oil was changed at 9600 miles, and the oil report stated that I was good for another 1000 miles. Since then I change at the 9300 mile mark.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    The 998 gets changed about every three thousand miles. That turns out to be about once a year for Linda's.
    The 1330 gets changed out at 9500 or minimum once a year (per the manual).
    Northern Kalifornia
    Default Oil changes
    2014 RTS SE6 first oil change done by dealer service dept. at 3k. and replaced with can am XPS semi-synthetic oil 5w20. Second oil change at 6k (9k on the odometer) with Amsoil 10w40 full synthetic along with a new filter. The XPS 5w20 cam am oil was sent in to be analyzed and returned minimal efficient. At 15k on the odometer (6k on the Amsoil) I removed a sample and had it analyzed. It returned also minimal efficient but with a slightly higher viscosity value than the XPS oil. At 18k on the odometer (9k on the 10w40 Amsoil) I changed oil and filter for the third time and again replaced it with Amsoil 10w40. I again had the Amsoil 10w40 analyzed at 9k and it still returned minimal efficient at about the same visocity as the analysis of the first tested XPS oil. It seems that most oils at 4k have reduced their viscosity rating to a stable point and hold that value for the duration. Folks that change oil and filter at 3k should be in excellent shape. However, those who run their oil until 9k as BRP recommends should be in good shape also as long as they change the filter too. Me, I'm going to continue to use Amsoil 10w40 and change it at 9k intervals along with a filter change.
    Mar 2015
    forrest above Reno, Nv
    Default Shell Rotella
    I change the oil once a year at the end of the riding season here ( 762 inches of snow just above us) I don't like to leave "old" oil in the crank case all winter .
    Kaos
    2014 RTS , Circuit Yellow
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Just had it done. I do it once a year. Let the dealer do it. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Feb 2012
    Spring City,Utah
    I have a V twin so my changes are more frequent then yours. BRP revised the schedule to every 4600 mi. I change mine every 4500 mi because that is easier to remember. I buy my filters,"O"rings and copper washers from BajaRon. Cheaper then BRP. I replaced my drain plugs with the plugs from Value Accessories.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2015
    South Carolina
    I have never changed the oil, (only taken to dealer), but I want to start. - I have a 2012 RT SE. I know about buying the BajaRon stuff, and just ordered a Gold Plug. Should I order several more Gold Plugs? Was going to buy BPR oil.
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Indiana Ken View Post
    I don't know what a "Gold Plug" is,but if it is to replace the stock BRP drain plug you only need two and I think anything more expensive then the ones in the Value Acessories catalogue is a waste of money. You need one 12mm and one 14mm.
    There are a couple of you tube videos on changing the oil in a V Twin and the owner's manual gives a fair description. With all of that information you should be good to go. It isn't hard just time consuming. Allow yourself plenty of time,especially to go back and review the videos. I have 3 ramps I put mine on for more space underneath. Any good JASO MA2 rated synthetic oil will work in your motor. Mike BlueKnight911 likes Valvoline 10w 40 4T synthetic. You can get it from WalMart. I use that or Shell Rotell 6T 5W 40 Synthetic. I have also used Royal Purple Motorcycle Oil 10W 40. BajaRon will make you a good deal on Amzoil along with the filters.
    So go for it go change that oil,..........you know you want to.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    The book says 9,300 miles, or one year: whichever comes first!
    Since I only can ride about 5,000 miles each year: I let the calendar's passing Months decide for me!
    Nov 2014
    NJ
    Question
    Thanks so much for all your replies, my Grandfather once told me that oil was cheaper then engines, so don't cheap out on the oil changes.
    You folks that are changing at 5,000 miles, is that with BRP or synthetic oil?
    2015 RTL , Red
    Jax Beach, Fl.
    I change oil & filter every 5,000 miles or 12 months which ever comes first. I always use BRP semi-synthetic oil & BRP filter.
    Cheers!
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Jan 2015
    southern WI
    Not real likely that I'll get more than 5000 miles in a summer, so my plan will remain the same as always with all of my previous bikes, and other stuff too.....I'll change oil and filter before it gets stored for the off-season.
    2021 RT Limited
    2016 RTS , Pearl White
    Default OIL CHANGES
    Mobil 1 10-40 Sportbike motorcycle oil and Can Am filter.
    There is a very good read about the ratings of oils by an independent person, not company. He had not tested BRP oil, but previous topics where the BRP oil had been sent in for testing indicated the oil had lost about 50% viscosity, bring it to an equivalent 20 wt in under 5k miles. That said, others here have run BRP oil for 100,000 miles with no known issues.
    The engine can handle the lower viscosity ok, the gearbox suffers the most.
    100,000 miles ....... who ???????................. Mike
    Jim might have...
    Aug 2007
    Greeneville, TN
    Can you give a link to that oil testing article?
    Oct 2016
    Faribault, MN
    It's on Cal-Sci's website I think https://motorcycleinfo.calsci.com/Oil.html I just read it this morning.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2016
    Canada
    i did mine oil change every 3000miles
    washable fitler and 5w40 full syn oil
    Active Member Samson's Avatar
    Aug 2016
    Prescott Valley , Az
    every 2500 miles, full synthetic and filter. Cheap insurance
    Jun 2017
    "Granite State"
    Quote Originally Posted by Samson View Post
    I'd go 3k, because frequent oil changes can't hurt much (well, maybe the wallet is an exception!) The intervals listed in the manual outright scare me regardless of oil type used. It's the contaminants (including moisture) etc., not just oil "break-down."
    🏁🏁 "Live Free Or Die" 🏁🏁
    Jun 2017
    Perth Western Australia
    Smile Oil change depends on....
    Quote Originally Posted by PW2013STL View Post
    Hi All, this is first post from me as I have just got my Spyder RT Limited 2917. Regarding oil change it differs on how you use your bike. If you have many 'shopping trolly' trips, short ones, you need to change more often. I just had my last long trip on my old bike, BMW K1200LT, and that was 9000Km over three weeks. From Perth in W. Australia to Port Macquarie NSW for the Ulysses AGM. Long trips like that your bike only has one cold start a day and as its cold starts that gives most of the wear and deterioration of the oil, the stretch of the change can be extended.
    cheers,
    Finn
