Results 1 to 4 of 4
    Member fjp800's Avatar
    Mar 2016
    tampa, fl
    Default 2016 F3 TRANSMISSION FILTER
    Is there a transmission filter for the 2016 F3 SE6? If so,m where it is located and what is the part number/ Thank you
    Dec 2012
    Murphy, NC
    Default Transmission Filter
    Read your owner's manual. It's in there.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Trans filter on the F3 is by your right toe
    The Hydraulic control module filter (HCM) is on the right side of the crankcase just like on the RT. It looks a little different than the RT one, but email or call BajaRon and he should be able correct me if I'm wrong and be able to fix you up!! Are you at 28,000 miles already?
    2015 RT , OEM Black Gloss
    As AeroPilot states, the good news is the service interval on the HCM filter (most call the transmission filter and that's close enough) is 28,000 miles. The bad news is, BRP charges over $100.00 for them. I sell them for less with free shipping. But they still are not cheap.
    Hope this helps.
