Ipod
Morning
I may have missed this and it may have already been discussed.
I have a 2014 RT Limited. I just recently received a iPod to use on it on long trips. During the trip it changes from iPod to Auxiliary. What can I do about this. Is anyone else having this problem
You wrote "I just recently received a iPod"
So, I presume that this is with a lightning connector, while the Can-Am cable is terminated with a 30 pins, therefore you should have a converter from 30 pins to lightning. This should also be secured (easy to get disconnected is there is stress on the cable with vibration while running).
Also, make sure it is a genuine apple converter as the others are known to be not working or unstable.
Good luck
I am connecting with the cord that came with the spyder and it Picks up as iPod sometimes and sometimes not. the plugs is still in it just switches.
Make sure that all of the plugs are fully seated.
If it's recognizing it as an I-Pod: that's a good start...
The question becomes: what is changing?
Other than a bad wire in the harness , a loose plug is about the only other reasonable choice!
I am connecting with the cable that came with the Spyder it switches automatically .
Good catch!
If you are using an adapter to go from the newer lightning connection, into BRP's 30 pin hookup, and it's not an Apple adapter: that could be the problem.
Only use the Apple adapters, and a whole lot of problems are prevented.
Good luck
Originally Posted by Dean
Morning
Once in a while my 2012 will do this.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
No.. I did not have a iPod at first so I just got one to connect with.
Good luck
I have had it happen. Usually its the main connector into the iPod. Make sure the iPod is mounted well and the connector is not jiggling at all. Just a little jiggle can cause a intermittent connection and when that happens it drops into AUX.
If that is not it, there is a cable problem of some kind. Perhaps your trunk cable is bad or the cable from the trunk to the radio is lose pins somewhere.
Bob
2011 RT-S SM5 - Black
This is going to sound really crazy, but do you by chance have a cup holder that is held in place by 3 screws on the left cluster.
If so this could be your problem. I had the same problem. I changed out the cup holder for a better one and the problem was cured.
I brought this up with the service tecks at the 10 year anniversary and With Lamount when I ran into him up there, both agreed this could happen. If nothing else check and make sure the screws are tight in that cluster.
iPod Touch 4th Generation
So after reading this thread I wanted to try to use an Apple device to play my music through the audio system of my 2010 RT. I first tried to use the iPhone 5s and the iPhone 6 using the converter and IPhone adapter. The iPhones were not recognized. I then found my iPhone Touch 4th Generation that I have not seen in five years. I updated the device to the latest iOS. I then used the iPod Converter that came with the Spyder. It works great!!!
IPOD
The only time mine has switched back and forth between IPOD and AUX is when my IPOD is near dead and has to get that initial charge. Only happens for about a quarter to half mile then is charged enough an stays on IPOD.
