Results 1 to 25 of 27
    Default QUESTION FOR THE ELECTRICAL - GENIUS'S
    This is what I want to do - eliminate the HUGH 12v plug ( and the necessary socket ) on my Sirius receiver .... I think I can put a Male RCA plug in place of the HUGH 12v plug and then put a Female RCA chassis socket in place of the 12v socket ..... I have the Male RCA and stripped it down to a center wire which is insulated ( I think + ) and bare copper wire ( I think - ) ..... I found this on e-bay ...item 252963605318 ( the chassis socket ) ......if you think this will work , how would I wire the Female if my assumption on the RCA male is correct ....... Thanks in advance ...... Mike
    Dec 2015
    Oakley Utah
    A picture or a link would help.
    2014 RTL Platinum
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Any matching plugs will work, just keep the + and - correct.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Default Go for it...
    I like the heated gear plugs or the tender plugs. As stated keep your polarity straight...��
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    Quote Originally Posted by pitzerwm View Post
    Somewhat true. As long as they are rated for the current you will be pulling. I like the battery-tender type plugs for this sort of thing.
    Something like this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    There is also these, which are the kind used by Can-Am on your Spyder https://www.amazon.com/gp/product/B0...A1K0O9XEM4PWVI
    2014 RTL Platinum
    Default PICS & LINKS
    I sooooooooooooooooooo wish I could do one or both ...............Mike
    Default SUGGESTIONS
    I like both of your idea's ...... but the RCA female is a CHASSIS type fitting so I can just drill a hole and fasten it on neatly .... no flopping around .................. the reason for this is ..... I actually managed to SHORT my Sirius out while plugging the HUGH 12v plug into the socket ...... I didn't even think that was possible ..... Mike
    Default = & -
    I think I have the polarity correct for the Male RCA ...... it's the female I'm not sure about ???? .... It's not apparent to me where to make the connections from the pic on e-bay ......... Mike
    Bossier LoUiSiAna
    Ok with yhat said look into these:http://m.ebay.ie/itm/DC12V-3A-2pin-P...EARCH:thumbup: still gotta watch polarity & amprage but does allow for a clean stable mount. Can even find some weather covers that are quit handy when installed properly. Here:
    https://m.banggood.com/Waterproof-3A...p-1053675.html
    (Ive had good luck scraping them from old boom box radios, after ive located the matching male end power supply & would wire up however i needed. + to the inside on male end has less chance of shorting out if you miss the hole)
    Mar 2015
    Brockport, NY
    Default USB power
    Sirius also offers a USB style power plug for many of their docks and radios. Don't know if that would be of benefit, but that's the route I went. Much more secure, I was having issue with the 12 v plug end working its way out of the socket during rides.
    2014 RT-S Pearl White
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Here is what I use. May or may not meet your intent. This plugs into the PowerConnect dock and uses USB power.
    https://www.amazon.com/Compact-Sport...usb+power+cord
    Chris
    2016 F3-T SE6
    Default THIS MIGHT WORK
    Quote Originally Posted by armyspydervet View Post
    Joel the Biker let me know that inside the HUGH 12v plug was a voltage reducer ( 12v to 5v ) ..... I read the specs on the one from Amazon and it also reduces the Voltage so this looks the one to use .... I have to make sure the plug will work in my model Sirius ........ Thanks much ...... Mike
    Default SOLUTION
    Quote Originally Posted by Brentc View Post
    SEE POST # 13 & 14 .......MIKE
    Default SOLUTION
    SEE POST # 13 & 14 ...... MIKE
    Mike,
    You said that you shorted out the receiver; do you need one?
    I've got an Onyx sitting here in my desk that's hooked up to nothing...
    Default SIRIUS XM RECEIVER
    [QUOTE=Bob Denman;1273298]Mike,
    I've got an Onyx sitting here in my desk that's hooked up to nothing... [ I should have worded that better .... I Shorted out the 12v socket ( which powered the Sirius receiver ) ...... it was fused, so no harm done ....... but Thanks for the generous offer your ............. Mike
    I'm glad to hear that!
    May 2017
    Texas
    Default Women
    No explanation necessary
    A winner is not the one who never loses. A winner is the one who gets knocked down a thousand times and never stays there.
    Nov 2015
    Myerstown, Pennsylvania
    I'm sorry for not understanding but what is a HUGH 12v plug? Is it made by a company named HUGH? I'm not familiar with it.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Default HUGH
    Quote Originally Posted by SteveLaoyster View Post
    .... It's OK, not everyone here understands me. Some ****** *** me and others even **** ******** !!!! me ...... But " HUGH " is a descriptive word that really doesn't need an explanation ..... Bob D. didn't even request a Pic , which really surprised me ........ There was a company named after Howard Hugh's .... I don't remember if they made 12 v plugs ... end of story .... I'm going for a ride now ...... Thanks for your response ....... Mike
    Default END OF HUGH 12V PLUG
    Thanks for all the responses ( especially yours Steve ) ...... I have made the purchase that will solve my issue ....Thanks " armyspydervet " ......... Mike
    Nov 2015
    Good Luck then Mike. Hope you don't have issues the new plug.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Default NEW PLUG
    I don't know if you went up to His post to see what the link connected to ????? ... but it was designed specifically for what I want to do ..... Mike
    Oct 2010
    Wisconsin Rapids
    Mike, I didn't think it was even possible to rewire anything FEMALE.
