I have tried this search engine to find a previous post with no luck. I found that something has dripped down the inside of my speedometer / tachometer area leaving dried reside on the inside of the face. Any I dealt what it may be? Bike has not been washed for months (Always clean) and is always parked in the garage. If anyone knows of the previous p[ost and can post a link - THANKS!!
My bike is a 15 RT with 9700 miles and still under warranty
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Your thread of yesterday can be found by just scrolling. I replied by providIng this link to a similar discussion, and noted that I am on my 5th lens (that was replaced by my dealer as an act of goodwill based on customer loyalty). BRP has not fixed this issue.
I had the same problem. Take off your dash as if you were going to replace your headlights. Owner's manual has instructions. As part of this process you need to pop out your instrument cluster. Once out, using a small screwdriver, you can pop off the plastic speedometer cover lens and simply Wipe Out the inside. I did it with no problem.
Wiping the inside of the lens will do nothing to clear up the deterioration of the coating on the inside of the lens. Buy a new one before you frustrate yourself trying to clean this one. $17.00 at Service Honda. Takes about 1/2 hour start to finish to replace. Will take longer to attempt cleaning.
