Results 1 to 14 of 14
Thread: Test
    Member TerryGrodi's Avatar
    Sep 2013
    Gloucester, VA
    Default Test
    Test
    2012 RTS SE5
    Aug 2013
    Northern California
    Default Test
    Failed, better luck next time!
    Sep 2013
    Gloucester, VA
    Default Map
    Tried to put the map with the states that I visited with the but it did not work. I will have to figure it out.
    2012 RTS SE5
    Aug 2013
    Northern California
    Wondering about that myself. I will be interested in others responses!
    Sep 2013
    Gloucester, VA
    Default Map
    I think that I figured it out. Or maybe I didn't.
    2012 RTS SE5
    Sep 2013
    Gloucester, VA
    Default Map
    I guess I figured it out. You have to edit your signature and put the picture in there.
    2012 RTS SE5
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by TerryGrodi View Post
    Yup! Took me a while too to figure it out.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Default Ooooo...!!🤔
    A test to grade....looks good to me...off center but that's Okay...
    ​2012 RS sm5
    Nov 2015
    Isn't everybody a little off center now and then?? It's what makes life exciting!
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Active Member LateLifeCrisis's Avatar
    Oct 2016
    Maryland
    Quote Originally Posted by SteveLaoyster View Post
    And it helps to be a bit off center when you're on this forum.........
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
    But it looks good to me!!
    Member Jmiklg's Avatar
    Mar 2017
    Waverly, NY
    Question Updating map in signature
    I've forgotten how I originally got it added. Can someone tell me where to find that map picture again and how to edit or color in the states?
    Thanks in advance.
    Mike
    Don't count the days ... Make the days count!
    Together, We CAN make a difference
    Jul 2015
    Dorr, michigan
    Test
    I tried to add it, lets see if it worked.
    2020 RT Limited , Petrol Blue
    Oct 2016
    Faribault, MN
    Default Visited States/Countries Maps in Signature
    There are several websites to visit to create a map of states/provinces/countries visited on your spyder for your signature block.
    EPGSoft.com https://www.epgsoft.com/VisitedStatesMap/
    Gas Food No Lodging https://www.gasfoodnolodging.com/vis...ates/us-canada
    AMCharts https://www.amcharts.com/visited_states/
    Visited States Map https://visitedstatesmap.com/
    MapLoco https://m.maploco.com/visited-states/
    These can then be saved as graphic files to your computer and then inserted in your Signature under the Settings section.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
