A Magic Mirror update.
I bought my Magic Mirror magnets and installed them on my '14 RT-S. I also bought the wide angle mirrors that stick right over the stock mirrors. So I took a ride to see how everything works. Then I had a problem. I noticed the mirrors needed adjusting. So I switched on my cruise control and with my right hand reached out to adjust the right mirror. Off popped the mirror, fell to the road with a crash and skiddled behind me to rest in the center of the road. I braked hard and turned around to retrieve the wayward mirror. Incredibly it was fine. Even the wide angle mirror was undamaged. I took it home to reattach it. I should say the wires should have held it, but I cut the wires last year when I added mirror lights. The crimp connectors didn't hold.
I lost reliability in the magnets. So I came up with a solution. I took off the top magnet and put the stock pin setup back on, still using the bottom 2 magnets.
Problem solved. The mirrors still pop off the way they always did but now I don't think I'm going to damage them doing so.
The instructions for magnet installation said to use the spacer between the magnet and body. I did that and didn't like that there was still a gap between the mirror and body. So I took out the spacer on the front magnet. Now I have what I wanted, a tight mirror that fits flush and looks like it should.
Buckeye Chuck
some have removed the top magnet and reinstalled the top stock clip while leaving the lower two magnets on..
I never liked or trusted butt connectors. Surprised you didn't use a plug adapter with wires you can spice into.
REPLACING OEM POST
Never
Adjust your mirrors while riding and you will avoid them falling off. I have had the magic mirrors on a little more than 2 months without issue. For safety I used the tethers.
Good to know...
New products will always need the ultimate "Joe Public" testing to see how well they really are. Thanks for posting your problem and solution will help make mods to the system where needed....
2012 RS sm5
SpyderLovers Sponsor
Agree completely!
We did a set this weekend. I did not like the front edge gap, or why the top post needed to be replaced. I think if the magnets are to replace the clips, leave the top post alone. Drop the price 33%, and only provide the bottom two.
Vicky, call Ann.
Joe Meyer
Vicky, call Ann.
That's a GREAT idea.
Except I don't know Vicky, or Ann.
But I'd consider the Magic Mirrors with this configuration.
IBA #47122
2020 RT Limited Asphalt Grey
Originally Posted by taxmyzer
[Never] Adjust your mirrors while riding and you will avoid them falling off. I have had the magic mirrors on a little more than 2 months without issue. For safety I used the tethers.
And you won't run off the road, cross into another lane, run into a ditch or hit someone or something!
Reason: Corrected grammar
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
I really like mine. I too built a tether, but that's just because I'm being paranoid. Leave the OEM top bracket in place or use all three magnet, either way it is a brilliant solution to a problematic design.
2020 RTL SE6
Reply
Yes, I was lucky to still have my stock mirrors. Somebody (me) thought the mirrors would hold tight. But I added the wide angle mirrors and sitting still couldn't get a good view of what's behind.
Forget the tethers, don't need them. Using the top stock pin you don't have to worry about them falling off.
Chuck
Funny,
It's strange I couldn't find anything from you or Lamont posting anything about this. I read SL.com every day. I posted this because I didn't want anybody to experience the same problem I had.
What the heck....
Buck
Vicky, Ann?
Vicky, call Ann.
Yup, hey, I have 2 magnets stuck to my workbench at home gathering dust. Maybe another rider has 2 also. We can get together and make a deal! But package them better than what I had delivered to my mailbox. They were at my home for a few days before I found them, stuck to the top of my steel box. Comical. Chuck
Mine will be here tomorrow. Good thing I have a plastic mail box.
I am probably going to leave the factory top one on. If so we could sell together. I will let you know tomorrow when they get here.
Ozzie Ozzie Ozzie
I agree, I love my MM, I just went out and adjusted my mirrors and all was good. I can't see them knocking off that easy. Mine are all staying, but will install tether now. Good luck.
2016 Can Am Spyder RT-S SE6
THE ANSWER IS
What the heck....
Buck
The postings were on this Thread ...." Magic Mirrors causing guages to misread " ...LaMonts was post #9 & mine was post #11
i too have the M M's and tricled wide mirrors. also homemade tethers . have
adjusted them with no probs. maybe one of those 1 in a million things. im
happy with both products.--irv
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
I also have MM's installed per instructions, did have the too large front gap, did remove that spacer, using all three magnets each side, have the TricLED Wide-Vue mirrors and rode 1700 miles of Midwest roads this weekend, no problems! And I can categorically say that NE, SD, and ND roads are much bumpier than MN roads. My Fitbit told me so....57,000 plus steps recorded while riding the Smackdab Saturday, rode 500 miles to the start and 500 miles back home, only got half as many steps recorded.... Mirrors didn't wiggle, bounce or come off. No tethers here either.. Not arguing, just my own personal experience.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Just my own experience too.
Put them on prior to going across country and back plus extra distance. So they have over 12,000 km/8,000 miles. No tether, no unusual gap, zero vibration or movement and that was over some rough roads that had me concerned about damage to the Spyder.
Just my 2 cents but I have complete faith in them.
Gary
States visited by Bike
I installed mine about 1 1/2 months ago, according to both written instructions and a YouTube video, and I did use the tether. I have noticed less vibration in the mirrors after about 500 or so miles. I had gotten into the habit of carrying spare top pintles & a torx screwdriver, since I had one mirror dangling from the bottom mounts because the top one broke. Then, I once had BOTH mirrors fall off at the same time, and of course the top pintles were broken. I feel much more confident now with the MM's, and have no worries of losing a mirror.
