Results 1 to 12 of 12
    Active Member SailnDive's Avatar
    Jul 2015
    WV
    Default Best tire replacement
    I will wear out the original tires the summer and I want to get a new set on hand. There is probably a thread on what the best replacement is. Any opinions? My bike is an RTS.
    There's probably about 14 GaZillion threads about tires...
    You'll need to find out if your dealer is willing to mount a non-OEM tire...
    If they won't: can you get it done at a nearby tire shop?
    Or perhaps even do it yourself??
    As far as tires:
    Kumho
    General
    Yokohama
    Michelin
    Seem to come up a lot...
    But they're FAR from the only choices!
    Happy shopping!
    Default BEST REAR TIRE
    Quote Originally Posted by SailnDive View Post
    I just posted them on the Thread ....215/60-15 Michelin Hydro-Edge report. Post #90 .. my answer is in BLUE .......................... For front the best imho is the Vredestein Quatrac 5 ...... go on the Tirerack.com and look at the sizes they have some that will fit for you
    Jun 2014
    ny
    i have vredstein for front
    Default VREDESTEIN
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    WOW.....your the first I know of to try them ........ Soooooooooooooooo what do you think about them ..... Thanks .... Mike
    Jun 2014
    ny
    no miles on them yet but they are excellent tires in wet, performance dry & even grip in snow.
    very similar to conti dws06. others may want cheap but i want good, my bike unlike others is
    not cheap and deserves better then chinese or basic tires.
    Default The Vredestein tire
    ....,and Please keep us posted on how they do perform ...... They are one of only a few Higher Quality tires in our sizes ....they even have 14 in that will fit ............ Mike
    Apr 2016
    Albany NY
    What about vredstein for the rear?
    Jun 2014
    ny
    Quote Originally Posted by TIMMB View Post
    not made i have looked, i will be using kumho on rear
    Active Member Jeffmal's Avatar
    Jan 2018
    Plantation,fl
    Default Vredestein tires
    Ok, so I may be taking one for the collective Spyder ryding community. I just purchased 2 front
    165/60r15 and rear 205/60r15 Vredestein quatrac 5 tires for my 2017 f3t. After they come in and get installed, I will do a follow up report on how they feel. They are highly rated and I am hoping for a vast improvement ! I hope nanny stays cool with this change!!
    Nanny should be fine with those sizes Jeff.
    The proportional difference in rolling dia front to rear with those sizes looks to be very close to the OE Spec difference.... It's when you go big up front & small on the back (or vice versa) that the Nanny gets upset - and even then, it really only upsets her a lot if you tend to push things a little.
    Gentle ryders probably won't ever notice the Nanny stepping in, but if you tend to brake late into corners &/or accelerate early on the way out, anything much different from the OE Spec proportional difference shows up PDQ & as a fairly noticeable intervention! And when she gets upset at speed or while you're ryding on the limit, it's more than just a tad annoying!! Safe, probably life & limb preserving, no argument there, but it can still be an aggresive intervention!
    And we all know that no matter how gentle or how hard you ryde, the ultimate aim is to ryde smoothly, ryde safe, and enjoy your ryde!
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Best
    No such animal exists!
    It's all in the rider's frame of reference.
    And you know what they say about opinions, right?
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
