Thanks Thanks:  0
Likes Likes:  1
Results 1 to 5 of 5
Thread: Fobo Accuracy
    Mar 2017
    Minnesota
    Default Fobo Accuracy
    Just wondering how accurate they are. My bike sat for a month because of a major construction project at home and when I went to get it out of a nice garage it read more psi in each tire than before I put it away.
    Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Temps are warming up... the tire pressure will also go up if you started with colder
    If two months ago you checked the tire pressure when temps were in the 40s, you will see higher pressures now that the garage temps (or wherever the Spyder is stored) is now much warmer. FOBO also has the feature of showing the pressures as either gauge or absolute pressure. Maybe your settings changed?
    Mar 2017
    Minnesota
    Quote Originally Posted by AeroPilot View Post
    Makes sense! Thank You
    Greenville Tx
    Make sure it is connecting. Sometimes it is just showing the reading the last time it was connected. When it connects it lightens up brighter.
    2014 ST LTD
    Corbin Fleetliner Saddlebags, Smuggler trunk, and Seat, Pitbull Cat Bypass,
    Akropovic Silencer, K&N replacement air filter
    XKchrome App Control Motorcycle LED Accent Lights
    Cal Sci Windshield, Lamonster LED headlights
    SP Missing belt guard, BR Sway Bar, Elka Shocks
    BRP Fog lights, SP Bump Skid
    SP Stainless Steel Grills
    FOBO TPMS, Lamonster Web Pegs
    Greenville Tx
    Quote Originally Posted by AY4B View Post
    It could be the pressure you remember is the cold pressure before you went for a ride. It heats up during the ride and the pressure goes up. That may be what you are seeing. The warmed up tire pressure and it may not have made a connection since. BTW, they are very accurate.
    2014 ST LTD
