Thanks Thanks:  8
Likes Likes:  19
Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Active Member RiverCity45's Avatar
    Dec 2016
    Texas
    I recently saw a YouTube video by a Spyder mechanic warning people that certain LED strip lights on Spyders, as they will mess with the canbus. He said he has had to fix a number of bikes that were having problems resulting from LEDs. In the following video, it's on RT with an added LED strip at the top of the trunk.
    2012 Spyder RS
  2. #27
    Apr 2012
    PA
    Chris,
    I know that you've got no time to fool with another problem... but I'd be at the dealership this morning, and standing on the Service Manager's desk about 7 seconds after they open up...
    They did this to your bike: they owe you a VERY prompt resolution!
    Agree 100%! Tom
    "I am the guardian of lost souls! I am the powerful, the pleasurable, the indestructible Mushu!"
    2016 F3Limited Intense Red Pearl
    Lamonster LED headlight and fog lights, Custom Dynamics LED fender and saddle bag lights, Can Am hitch, Can Am rider and passenger backrests, Baja Ron sway bar and Lamonster dog bones.
  3. #28
    Apr 2012
    PA
    Glad you figured it out so you can ride. Tom
  4. #29
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    Quote Originally Posted by RiverCity45 View Post
    I saw this months ago and didn't believe it. I'm still not sure why the lights were causing my canbus to go haywire after the top case was installed. But I checked and double checked. Plug the lights in, bike is a no-go. Unplug the harness, bike works flawlessly. Oddest thing I've seen.
    Chris
    2016 F3-T SE6
  5. #30
    Active Member UtahPete's Avatar
    Dec 2015
    Oakley Utah
    Default After-market LED's interfering with the CANBUS?
    Quote Originally Posted by armyspydervet View Post
    There's got to be something wrong with the way the mechanic wired the lights. There are many RT's on here with add-on LED lights (including from TricLED) that have not experienced any problems as you are describing.
    2014 RTL with KompactKamp pet trailer
  6. #31
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi armyspydervet,
    Re: As soon as I disconnected the LED lights, everything went back to normal.
    How did you bring the power to these LED lites? Did you come from the battery or from some other source?
    Just wondering.
    Re:
    They won't be going back on until I can get the LEDs professionally installed.
    Are you thinking that a 'professional' will do something different as to the install?
    Again, just wondering.
    Jerry Baumchen
    PS) Always nice to see some progress on a problem. At least you have it partially taken care of.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
  7. #32
    Nov 2015
    Occoquan, VA
    Quote Originally Posted by JerryB View Post
    Hi armyspydervet,
    Just wondering.
    Re:
    Jerry Baumchen
    i appreciate the questions. I may have done something during the install, I installed them myself. They were connected with a harness that came with the lights. Unplugged the tail lights, put a harness in between them and ran the wires from the harness to the lights.
    I am an amateur (at best) on maintain my spyder. I may have not plugged something in correctly it was causing a short or something to not be connect right. I'm not blaming the lights or the dealer at this point. It was there idea to start disconnecting the aftermarket lights to see if that helped. It worked. Now when I have time, I'll reconnect them one by one except the lights that were causing the problem. Those I'll leave disconnected until someone smarter than me can hook them up.
    Chris
    2016 F3-T SE6
  8. #33
    Nov 2015
    Occoquan, VA
    Mechanic only installed the top case. Maybe he knocked something loose on my harness that caused the issue, I don't know. At least it's running for me to ride to TN this weekend.
    Chris
    2016 F3-T SE6
  9. #34
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    I had a wire not seated in a harness for my HMT that caused some issues. Once I got it seated properly nothing has acted up. The harness even looked ok until I tugged a bit.
    The one thing I like to also do is use relays so that way any aftermarket lights are isolated from that he other systems.
    2012 Cadillac CTS-V Black Diamond
    2011 RT-S Viper Red
    2010 RT622 - Black
    Chrome: Handlebars, Windshield Mount, Mirror Uppers, Upper and Lower wind deflectors, Pegs, Boards, Casting/Mounts, Exhaust Guards and Tips, Brake Pedal; Sena SMH-10D's and SM10, Stebel Nautilus Compact Horn, Hopnel Nets, JT's Intake (Airbox and Resonator delete), Upgraded Vac Hoses, Attwood Blower thermostatically controlled, Experimenting with Fan Reversal
  10. #35
    May 2014
    Beaverton, Oregon
    Hi jwulf74,
    Re: The one thing I like to also do is use relays so that way any aftermarket lights are isolated from that the other systems.
    ^^^^^ This is the reason as to why I asked.
    I will be wiring a 3rd taillight soon & have all of the parts to do it this way.
    Jerry Baumchen
    2008 GS SE-5
  11. #36
    Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    I've found that the electrical systems on these trikes can be temperamental. I still haven't gotten my problem solved but have some ideas.
    http://www.spyderlovers.com/forums/s...59#post1260559
    AKA Jud Smales, new Spyder Ryder!
    The Critter 2016 RT-S
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Ultraguard half cover
    Gremlin bell from my son
