Results 1 to 9 of 9
    Sep 2015
    New London. Texas
    Default Brembo rear brake caliper
    Anybody have the dimensions of the piston diameter and hole size and spread so I can make a tool to compress piston? The kits you get from the auto parts stores do not have one that fits.
    Oct 2011
    Kalamazoo, Mi
    Default brembo rear caliper
    get yourself a heavy duty needle nose pliers, works great
    2018 F3-T
    2018 F3-T , Pearl White
    I have a prototype tool that I had made. I'd be happy to send it to you if you can give me some feedback on it.
    Sep 2015
    New London. Texas
    Sounds good. What do you need?
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    After you screw the piston back in so that the new pads can be installed, what do you need to do, if anything, to readjust the parking brake?
    Mar 2013
    Quote Originally Posted by rcturner View Post
    You should not have to do anything to the parking brake. The brake will only move as far as needed, so with the new pads it will not have to travel as far as when your pads were worn down.
    I did not have to adjust my parking brake after my pad change.
    I also used needle nose pliers to turn back the piston - worked great.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2015
    New London. Texas
    I let my piston extend fully by not removing brake cable. My bad. Pulled pads and used needle nosed pliers and pressure for 45 minutes with no progress and a very sore shoulder. Made due with a crude piece made and a clamp. The clamp could exert enough pressure to rotate piston back in. All good now, but I want to make myself a proper tool. And yes, just put your new pads on, pump brakes out before you set parking brake and all is good.
    Jul 2011
    Mitchell, Ontario, Canada
    The parking brake is self adjusting. Cycle the parking brake a couple times and it will be adjusted.
    Quote Originally Posted by altonforbus View Post
    Email me at fyredad@hotmail.com
    I can ship the prototype out to you tomorrow.
