Brembo rear brake caliper
Anybody have the dimensions of the piston diameter and hole size and spread so I can make a tool to compress piston? The kits you get from the auto parts stores do not have one that fits.
brembo rear caliper
get yourself a heavy duty needle nose pliers, works great
2018 F3-T
SpyderLovers Sponsor
I have a prototype tool that I had made. I'd be happy to send it to you if you can give me some feedback on it.
Sounds good. What do you need?
After you screw the piston back in so that the new pads can be installed, what do you need to do, if anything, to readjust the parking brake?
You should not have to do anything to the parking brake. The brake will only move as far as needed, so with the new pads it will not have to travel as far as when your pads were worn down.
I did not have to adjust my parking brake after my pad change.
I also used needle nose pliers to turn back the piston - worked great.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
The parking brake is self adjusting. Cycle the parking brake a couple times and it will be adjusted.
Email me at fyredad@hotmail.com
I can ship the prototype out to you tomorrow.
