Results 1 to 19 of 19
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    Default 2014 RT acting up.
    Two Saturdays ago my wife and I get the Spyder out for a ride to Albany and the gas gauge reads Empty and the little gas pump light was on. I thought for sure I had filled her up the night before. Any ways going down the road to the gas station, the needle goes to full and the light goes out. We continue on our way with no problems the rest of the day.
    fast forward to the next Friday, I stopped to pay electric bill, go to start Spyder, no start. The little box at the bottom middle of the screen is Orange with a key picture. Turn key off, turn it on, the box flashes Orange w/ key for half a second, than flashes "check engine" half a second with check engine light on in the tachometer, light goes out, bike starts up. Continue on my way 1/2 dozen starts, no problems the rest of the week. Until today. Gas gauge is dead agin.
    i can't get to the dealer until the end of the month so i guess I'm asking for opinions. Is my Spyder working towards going Nuculer with the Orange screen of death?
    my bike is a 2014, still on warranty just can't get it to the dealer until the 27th.
    Oct 2011
    Kalamazoo, Mi
    Default 2014 acting up
    First things first; have you looked at and tightened your battery connections. Do you keep it on a maintainer when you're not riding??? How often is it taken for 2-4 hour rides??? Sounds like a bad battery, take it to batteries + and have them load test it for you. Good luck, let us know what happens
    2018 F3-T
    2018 F3-T , Pearl White
    It is sounding symptomatic of electrical. Battery connections would be the first place to check.
    Jun 2010
    Las Vegas
    Pay your bills online and take the time you usually spend paying them in person to go on a long ride instead. Your battery will like you better.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2015
    sherburne, ny
    Good idea Ann. But when you live in a one stop light town like I do, they are not set up for automatic pay. 5pm is rush hour, it drives me nuts! Its 5 minutes long!
    Default What they said...
    Start with electrical connections. Especially if any work has been done with lights etc.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2015
    sherburne, ny
    So i got a little time and opened up my battery on the RTS. Not sure if you can see but lots of corrosion on the Terminals (white stuff. I guess it's called corrosion?) so I suspect it is the battery. So this afternoon I'll give it a good cleaning and slap it on the charger, put a little dielectric gel on the terminals. I may just replace the battery, it is over 3 years old. I will probably run by the dealer on the 27th. May just have them check it out. My son and I are to ride up to Mount Washington next month.so piece off mind.
    as for a battery is it best to stick with the stock Yuasa?
    I'm glad that you have found a good potential solution to the problem.
    I replaced the battery on my 2014 Last Month when it was in for some servicing. It was there anyway, and it saved me from another "Down Day" of no riding later this Season.
    Mar 2008
    Hesston, PA
    Default Maybe the start of a DESS issue
    Quote Originally Posted by Jheck View Post
    Sounds to me like you may have 2 problems...You may be starting to get a DESS problem with the flashing orange key...And maybe a fuel gauge issue???
    Dealer can check with Budds if you had a DESS failure...
    Dec 2015
    Oakley Utah
    Default Replacement batteries
    So i got a little time and opened up my battery on the RTS. Not sure if you can see but lots of corrosion on the Terminals (white stuff. I guess it's called corrosion?) so I suspect it is the battery. So this afternoon I'll give it a good cleaning and slap it on the charger, put a little dielectric gel on the terminals. I may just replace the battery, it is over 3 years old. As for a battery is it best to stick with the stock Yuasa?
    The Yuasa is a good battery and is standard on a lot of 'foreign' bikes. But, if you're not near a motorsports dealer that carries it, then get any recommended brand in the same size. BatteriesPlus carries a good selection.
    For a thorough discussion on batteries, I've found this site useful; https://www.batterystuff.com/batteri...rcycle/can-am/ https://www.batterystuff.com/kb/arti...ry-basics.html
    As for the 'corrosion' on the terminals, I've seen a lot worse in my day on fully operational batteries. Go ahead and clean them if you want but I doubt that's the issue. I'm more inclined to think it's something in the electronics as others have suggested.
    2014 RTL Platinum
    Quote Originally Posted by larryd View Post
    It's not a DESS issue... there would be tons of indications that it was the cause.
    Dec 2015
    Oakley Utah
    We live in a no-stoplight rural community and have had no problem paying any of my bills through my bank.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Default Sure sounds like a faulty ground or another loose connection since it's intermittent
    Two Saturdays ago my wife and I get the Spyder out for a ride to Albany and the gas gauge reads Empty and the little gas pump light was on. Any ways going down the road to the gas station, the needle goes to full and the light goes out. We continue on our way with no problems the rest of the day.fast forward to the next Friday, I stopped to pay electric bill, go to start Spyder, no start.
    The little box at the bottom middle of the screen is Orange with a key picture. Turn key off, turn it on, the box flashes Orange w/ key for half a second, than flashes "check engine" half a second with check engine light on in the tachometer, light goes out, bike starts up. Continue on my way 1/2 dozen starts, no problems the rest of the week. Until today. Gas gauge is dead again.
    From the symptoms, I doubt it's the battery. It sure sounds like an intermittent bad ground or other loose connection to the computer. Before replacing the battery, put a meter across the terminals and see what the reading is. Pull it out of the bike and take it to a local garage if you don't have the equipment. There's no point in wasting time on the battery if that's not the issue, so rule it out first.
    2014 RTL Platinum
    Jun 2015
    sherburne, ny
    So some plans changed and I took the time and ran my bike to the dealers. Gave them all the particulars and left it with them to be checked out. I'll let you all know what they find. Being bikeless is giving me time to think about getting a second bike (2 wheeler).
    Sep 2016
    clark county indiana
    Default a guess before we know
    I am going out on a limb and say , loose connections in the wiring harness from the dash too the wire connections down line , { maybe a mouse , or just worked its self loose ... } just a guess ! hope it is easy , new battery , and 1 new fuse ...
    Jun 2015
    sherburne, ny
    If its a mouse....... me and the cats are going to have a serious talk!
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    if you need a new battery, the stock Yuasa is OK.
    Back when I rode BMWs, the cat's meow was an Odyssey battery, if you could afford it. Longer lasting than most stock batteries. On their bike applications page, they don't show one for Spyders; you might have to settle for close enough size-wise. Call them and ask.
    Sep 2014
    Central Alabama
    Talk, talk, talk....... we're unionized!
    Jun 2015
    sherburne, ny
    Got my bike back this last Friday. They had to replace the DESS module. Got on it took it to doctors appt. got back on after appt. and Gas gauge says E, little gas pump light is lit up. (Bike is full) and now the Temp. Gauge stays at half way point all the time.????? So now back to the dealer. So the question is- ride it like it is or tye it up at dealers for another 3 weeks??? Very aggravating. Bike only has 8000 miles on it.
