Results 1 to 8 of 8
    Apr 2016
    Texas
    Default Removal of Chrome Emblem on Rear Trunk
    Does anyone know how to remove the rear emblem from the trunk on a 2015 RT? Someone badly scratched the trunk lid and i need to repaint it. I would like to remove the emblem to get a good sanding/paint/polishing job.
    Thanks for your help...
    Lone Star Spyder
    Jul 2008
    It's put on with two sided tape. I stuffed a screwdriver under mine. the tape gum will come off with gas on a cloth.
    Active Member krazykat's Avatar
    Feb 2013
    Cape Coral, Florida
    Heat it with a hair dryer first. This will soften/loosen the glue.
    2014 Cognac RT Limited #185 (destroyed in T-Bone wreck 3/21/2014)
    2014 Cognac RT Limited #5333 (replacement 5/16/2014)
    2018 Champagne RT Limited #1002 (traded 1/31/2018)
    Jul 2014
    Mint Hill, NC
    Let it sit in the hot Texas sun to let the adhesive get as soft as possible. I would then try to work it off with a plastic spatula.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Bike-O-Din's Avatar
    Apr 2012
    Cross Junction, VA
    Default A trick from the dentist
    Dental Floss is a great tool for removing double sided tape. Just get it started under on of the edges and "saw" through the tape. If is amazing, and a really cheap tool.
    After the tape is cut, you can remove it in a variety of ways, but this will get the emblem out of the way.
    2011 RT-S , Silver
    Apr 2016
    Texas
    Default Thanks everyone!
    Quote Originally Posted by Gary View Post
    Thanks for all the help. I heated it with a hair drier and slowly pried it off with a spatula.
    Thanks all!
    Mar 2017
    Oct 2014
    Ga
    Another effective method is by uing a hair dryer and fishing line
