Cheap Throttle Control
I just got a new 2106 RS and found that the throttle control was too loose for my taste. If I took my hand off it, it sprang back to idle. SO, I removed the bolt at the end of the control from the handlebar and the inside of that plastic piece has 2 stepped rings. I found a thin rubber washer (I could have use inner tube rubber) that fit inside the handlebar but also around the larger inside ring. I then replaced the end piece and tightened it down just to where the throttle would hold in position, I used it this weekend on a 100 mile trip, and it worked great. A cheap throttle lock for pennies!!
A minimal twist turns it off. It just makes the throttle a little sticky.
It's your bike, and it works for you: I'm glad that you found a cheap way to accomplish this.
Over-ride a safety feature on a $20k bike just to save money? Really?
2014 RTL Platinum
....... PLEASE TAKE IT OFF ........
Yes Mother !!
I've been riding with "throttle drags" on all of my bikes since WAY back when they were standard equipment.
I make mine with a length of thin "bunje cord" stuffed between the throttle grip and the switch assembly right in front of it.
What is right for YOU isn't right for everybody.
I haven't decided if I'm going to add that to my Spyder yet. Having a real cruise control makes it less useful.
To Each his own....
Regardless of how long one has done this and managed to stay safe it is a dangerous risky way to ryde. I know you are talking about two wheelers/trikes with manual clutches that can be pulled as a instant release and just a revved up engine. The semi automatic ones do not have that luxury. But then I'm not crazy about any type of cruise control on motorcyles with twist throttles. There are many such cruise controls for a less than bottle of beer but it is a choice and to each his own...We do think safety first around here...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Are there really bikes (with any number of wheels) where when you let go of the throttle it doesn't return to idle?
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
There USED to be...
There USED to be...
Why do you think there isn't now? Could it be because the demand for the return option was so high the manufacturers decided to make them all that way, or maybe the safety people thought it was a good idea to make them all that way? The first auto-return bike I rode took some getting used to letting it return on it own.
Ed
They told me not to give up on my dreams, so I went back to sleep.
Champagne 2017 RTS SE6
Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
If you take your hand off the throttle, it's SUPPOSED to spring back to idle. I bet you'd freak out if you took your foot off the gas in your car and the engine didn't slow down.
They make all kinds of mechanical throttle locks, Kuryakin comes to mind, but they can all be easily released.
Sorry, I don't mean to be judgmental but this is a safety issue. You're also making yourself liable in an accident.
It's your bike to do with as you please, and NOONE has the right to stop you, but I STRONGLY urge you to reconsider.
IBA #47122
2020 RT Limited Asphalt Grey
HELPING OTHERS
Originally Posted by Easy Rider
Yes Mother !!
Dear - Easy Rider ... I'm nobodies mother and don't pretend to be one...... You appear to " THINK " this Mod is a Good Idea !!!! ... If next week ... A friend of the OP posts that HE lost control of His Spyder , crashed and was injured or worse DIED ..... Please tell us what your Next post about this would be ............. just a thought ...... Mike
When the hits the fan, e.g., when that 85 year old Q-tip with coke bottle bottom glasses makes that left turn in front of you, are you going to remember to close that throttle before or after you your trousers?
throttle control
If you can afford to purchase one of these trikes; you can afford to replace the right handle bar control with an RSS electronics package which includes the cruise control pre-wired from the factory.
Then you've got a cruise control that works and you don't have to think about releasing the throttle to slow down. $3000.00 model upgrade for ~$400.00; good first farkle for you!! JMO Mike made me do this!!!!
2018 F3-T
