Results 1 to 12 of 12
    Active Member connie9003's Avatar
    May 2013
    Murray, KY
    Default 2011 RTS won't start :(
    2011 RTS issue, any thoughts ? Bike wont start, battery is fine is starts to go on but never actually rolls over almost like its out of gas but has a full tank ?
    2014 RT , Yellow
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    Not to sound stupid, but, is the kill switch in the off position? I did that 1 time and felt like a fool.. Lesson learned..
    May 2013
    Murray, KY
    Quote Originally Posted by wd8ajj View Post
    Already checked that not it
    2014 RT , Yellow
    Mar 2015
    Brockport, NY
    Default Little more detail
    Does it crank over normally and not start or is it laboring to turn over and not starting? If it's the latter then you may need a new battery.
    2014 RT-S Pearl White
    May 2013
    Murray, KY
    Quote Originally Posted by Brentc View Post
    Plenty of battery its like it just wont fire up ? I
    2014 RT , Yellow
    Default Depends....
    If the motor is cranking normal when starting but will not start you need to try the TWO (throttle wide open). Twist the gas all the the way open and hold it there and crank the engine for 10 seconds or more. Then release the thottle so it snaps shut and start normal. You may have to try it a few times. If it ids not cranking then we need to look at other problems...
    ​2012 RS sm5
    Bossier LoUiSiAna
    Go with T.W.O. & u report full tank of gas, did you just fill up ? It may have got some trash in line some where or air if you ran way low & the T.W.O. Will help push it thru or at least get some flo going. Fyi there will be some gas smell lingering after it cranks. It will not be there on your next crank unless you T.W.O. again.
    You should be ok with just doing it once.
    Let us know
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Apr 2017
    North Central Florida
    Quote Originally Posted by connie9003 View Post
    Terminology often is a problem.
    I don't exactly understand "starts to go on but never actually rolls over".
    Does that mean that the starter runs at normal speed but the engine never fires ?
    Or does it mean that the starter tries to turn but never really goes ??
    Either way some basic tests need to be made and if you don't feel comfortable with doing that yourself, call the shop.
    Jul 2011
    Mitchell, Ontario, Canada
    It's flooded. Do a wide open throttle start. Twist the throttle to wide open and hold it there. This turns the fuel injectors off. Press the start button for 10 seconds and let it crank. Stop and let the starter cool for 1 minute. Do it again. Again another 1 minute cool. Then try a normal start.
    2018 F3 LIMITED
    You should be smelling some pretty strong gasoline vapors...
    Throttle wide-open, and follow the instructions above... good luck!
    Active Member Santa & Mrs Claus's Avatar
    Sep 2013
    Saskatoon, SK
    This just happened to our 2011 Spyder. It turned out to be the battery.
    Try boosting the battery when trying to start it. It worked for us. Than we had the battery replaced.
    Please get back to us and let us know the outcome.
