Reverse gear actuator part number
Greetings!
Does anyone out there have a good part number for the reverse gear actuator on a 2014 RT Limited? I tore it up accidentally backing over a tree stump in my yard.
I've tried to rebuild it, but it still won't engage with the motor/gear assembly inside the actuator itself. The closest dealership is having a hard time finding the correct part number (which is scary in itself). I know I can change it out because I've had it all apart trying to rebuild it already. I just need a good part number so I can replace it.
Many thanks to anyone with a good microfiche or parts list that can provide this info!
Check out this link. http://www.can-ampartspitstop.com/oe...ctrical-system
I believe the part you are looking for is ref# 535 Actuator
710003776
$55.99
2015 Can Am Spyder RT Limited
now that you have the part number check out Cheap Cycle Parts and do a little price shopping.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Old topic - where is the actuator actually located?
Found it - below the drive pulley.
The best substitute for brains & knowledge is....................silence.
