Results 1 to 22 of 22
Thread: "Bad Key"
    Active Member Mikind7's Avatar
    Apr 2015
    Orangevale Calif
    Default "Bad Key"
    Does anyone know if there is a work around for a "Bad Key". Happening all to often lately. Made an appt. for next week at the dealer but don't want to get stranded in the mean time. TIA
    2015 F3 SE6 Black and Chrome, Smoothspyder Backrest and more to come.
    Dec 2016
    Somewhere USA
    Quote Originally Posted by Mikind7 View Post
    Carry the other key. When the first one fails then immediately put the other one in. If that fails then you know its the computer.
    Not trying to be a smart *ss but that's what I would do.
    Apr 2017
    North Central Florida
    Quote Originally Posted by Road-Kill View Post
    That's what I would do also.
    Nothing disrespectful about saying that.
    And if you only have ONE key, get another one made ASAP.
    You are more likely to become stranded by human error than from equipment failure.
    It sounds as if the DESS is giving you fits...
    Check out Deanna's thread about this issue in the RTs...
    Apr 2015
    Orangevale Calif
    Tried both keys, I thought maybe since I carried both keys that was the issue but happens with one or the other or both near the bike. I am just trying to determine if there is a set of switch codes like on my old Harley to bypass security. I have an appt to have the DSS checked
    Sep 2013
    Houston
    Readers Digest version...
    DESS
    Have it turned off
    Live happily ever after
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    If it's gonna think that you're stealing your own bike : just kill it!
    Then you'll be able to get yourself a couple of un-chipped keys, and use them.
    (Save the good keys for the important days!)
    Apr 2015
    Orangevale Calif
    DESS
    Have it turned off
    Can it be easily disabled?
    Apr 2017
    Find a bike thief and ask him.
    I certainly hope not.......or else it would be worse than useless.
    Active Member SpyDerSts's Avatar
    Aug 2015
    Columbus,Ohio
    Default Yupp. DESS
    Yupp eventually u won't be able to start,only push it...lol. Likely the DESS and the antenna parts to it need replaced. Been there done that on F3S model too!
    '15 F3S SE6 Pearly White (Hers)
    '16 F3S SE6 Special Series Triple Black (His)
    Sep 2013
    Houston
    Quote Originally Posted by Easy Rider View Post
    Its worse than useless.
    Easily defeated. It only serves to keep you from riding. For the uneducated casual thief, the key alone is more than sufficient.
    Sep 2013
    Houston
    Toggle one setting in BUDS. Even without a working key.
    Active Member rays hell's Avatar
    Hiram Ga.
    Default DESS
    DESS
    Have it turned off
    Tell me more JC, is that even an option, would it it have to be done by a dealer,
    and what would it cost ?
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    Oct 2010
    Wisconsin Rapids
    I got the bad key code. Dealer checked computer and either updated it or reset it. No problem since.
    Sep 2013
    Houston
    Quote Originally Posted by Machinegunner View Post
    It will be back. Likely when you are far from home or in a hurry.
    Sep 2013
    Houston
    Quote Originally Posted by rays hell View Post
    Requires a Megatech licence version of BUDS. Most dealers do not buy this level licence. There are a few that do and a few independent shops as it allows for much better diagnostics and settings. Its not cheap.
    If we are not doing anything else, we charge $35 for a BUDS diagnostics report and can disable the DESS while in there. If we are doing any other work at the same time, I usually flip the toggle if asked free of charge. I never alter this setting unless the owner specifically asks for it.
    Hiram Ga.
    Default DESS
    Thanks JC, it would be nice to know you could get a key made without having it programmed
    or cloned and peace of mind every time you put the key in and hit the starter the DESS is not
    going to sand in the way.
    I'll be asking my dealer about this.
    Monique,
    factory floorboards
    added topcase
    Vermont
    I started a thread " D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!! posted on 8/13/2015 it is 26 pages long with some very helpful info, and pictures. Like Bob said in his post # 4. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Bryant, Arkansas
    Dealer needs to use buds to let the computer re-learn the keys, should be a warranty item. Very simple procedure and should not take more than 30 minutes.
    Cruzr Joe
    Vermont
    Quote Originally Posted by SpyDerSts View Post
    get the antenna/and the switch replaced. I have had it done twice( July, 2015, and again Aug. 2015 both were covered under warranty) on my 2014RTS-SE6 I also started a Thread.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Have your dealer reprogram the keys, change the switch, change the D.E.S.S module. I have had this done on my 2014RTS-SE6. Also, I started a thread " D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!!!!!!!! It has some very helpful info. with pictures. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Cruzr Joe
    Yes, it is a warranty item, look at my thread" D.E.S.S KEY CODE AGAIN!!!!!!!!!!!!!!!!!! I posted it. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
