Results 1 to 11 of 11
    May 2016
    Western Mass
    Default 2009 Automatic , 20 mph noise
    from maybe 19 mph to 22 mph I get a noise that sounds like a bad brake noise. It does not change when I apply the brakes, so I am thinking it is somethingelse. Wish I could pinpoint the location, but having trouble with that. My guess is it is not the rear wheel area.
    Any ideas ? , Thanks, Dave 7000 miles on bike
    Do you have any way to jack the bike up, and get all three wheels off of the ground?
    I would try spinning each wheel; you might have a bad bearing...
    Sometimes, the belt will squeal as the cogs engage and disengage from the sprockets. A small dab of lithium grease that is applied to the belt will stop that.
    Good luck, and happy hunting!
    May 2016
    Western Mass
    I will try that in the next few days when I change the oil, it was not as noisy last night when we went for a ride
    Thanks, Dave
    Can't help with the advice but note your new around here.
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Default sound
    Is it a growling sound? My 2009 RS makes some noise, at that speed, in first gear. Seems to be a combination of road surface, tire type and the belt noise combined. Mine changes as the road surface changes. My Nomad has a similar noise on some road surfaces, when running in the lower gears. So if the noise changes, or goes away, on different road surfaces, it is most likely caused by the tires on that particular road surface.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    May 2016
    Western Mass
    A little more info,,,, The noise is not road surface related , it does not matter what gear you are in , the front wheels spin freely and don't have any play. I am going to go for a ride and do a couple panic style brake stops and see if that changes it at all. Thanks for your comments and replies The mystery continues,,,,,
    Default STRANGE NOISE
    Quote Originally Posted by Dave1330 View Post
    ..Question - you didn't say whether the noise goes away after you get to 22mph ..... Mike
    May 2016
    Western Mass
    Yes it is only from 19-23 , it is completely quiet the rest of the time. On some cars there is a metal piece that is on the disc brake pads and when they get worn down it contacts the rotor and makes a squeecking sound, if you know that sound, that is what this sounds like. , but it doesn't appear to have anytjing to do with the brakes. hitting the brakes doesn't stop or change it.
    Default NOISE 19 TO 23 MPH
    Yep, this is very ODD .... something like this is going to be extremely difficult to pinpoint ..... But because it goes away I don't think it is serious ..... Mike
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Check your Y pipe gaskets for leaks. They sometimes can make strange noises when they are going bad. JAT
    David
    Default NOISES
    Quote Originally Posted by Warlock View Post
    David
    Possibly but not likely ..... if a gasket is leaking ( broken ), imho it's broken ALL the time not just between 19 and 23 mph range ..... Mike
