Results 1 to 25 of 25
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Anyone know how to remedy Hyperflash?
    Had some LED's put on couple weeks ago. Have fender lights hooked to turn signal. When I put on turn signal, it flashes normal about 2 times, then hyper flashes. I tried doing what Lamont does on his video about hyper flash, but it does nothing for me. It's on a 2014 RTL
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Active Member spyderfever's Avatar
    Gerald, MO
    Some people have had the same problem and were told to have the engine running when you do it. It may be worth a try! Good luck!
    2015 RTS Spyder, Intense Red Pearl, Baja-ron swaybar & links, Custom Dynamics trunk brake light, third & fourth brake lights from TricLED, Spyderpops bump skid, led lights on turn signals, Rear Elka shock, sheepskin seat cover & a new Black Freedom Trailer. We love our Spyder!!!
    Mar 2015
    NE Kansas
    We also have a 2014 RTL and Lamont's instructions to correct the hyper flash worked for our bike as written in the Spyderpops kit.
    ...They worked just fine on my 2014 RT-L also.
    But you do have to make sure that you follow the instructions EXACTLY s he laid them out...
    https://youtu.be/gpuEqpiTm4M
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    TricLED told me to hold the emergency flasher button for 30 seconds with the engine running, because the reset is sensitive to voltage. That's worked for me.
    May 2010
    Knob Noster, MO.
    Default Question about hyper-flash?
    Will hyper flash do any damage to the electrical system? I'm in the process of putting on LED lighting, and have it. I kind of like it, but not sure if it will damage the system.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Apr 2016
    Bloomington, Minnesota
    I had the hyper flash for my entire trip home from Spoyderfest. The bike was very wet from the torrential monsoon we rode home in. Once the bike dried out the hyper flash went away.
    Apr 2016
    I had the hyper flash for my entire trip home from Spyderfest. The bike was very wet from the torrential monsoon we rode home in. Once the bike dried out the hyper flash went away.
    Jun 2016
    Canton, MI
    [Followed them to the letter, about half a dozen times.
    QUOTE=Bob Denman;1263464] ...They worked just fine on my 2014 RT-L also.
    https://youtu.be/gpuEqpiTm4M[/QUOTE]
    Jun 2016
    Canton, MI
    Tried that too. Does not work either.
    Quote Originally Posted by MisterP View Post
    Mar 2015
    NE Kansas
    I would try calling the vendor from who you purchased the items. Both Spyderpops and Tricleds have awesome customer service! Their staff really know their products and probably talk you on to the right troubleshooting steps.
    Quote Originally Posted by Blue Star View Post
    Nope: it's not going to hurt anything!
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I have a2017 RT-s, and have "reset" the hyper flash a few time since adding LED's. This morning, it's back. So, the procedure from Lamont doesn't seem to stick.
    I remember reading in a previous post that adding a ?300ohm? resistor inline will also stop it? Anyone remember??
    Thanks
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by bcer960 View Post
    Thanks
    Mine didn't stick and kept coming back until I ran through it while the engine is running. Hasn't been back sense.
    2020 RT Limited , Petrol Blue
    Active Member Freegle's Avatar
    Feb 2016
    South Carolina
    Default Ristors
    Thanks
    If you are going to add a resistor you will need to start at 100ohms and work your way up. I put a 330ohm resister in line with my mirror turn signal and the turn signal was so dim that it almost look like it was not on. I went to a 100ohm resister and everything worked for me. These resistors are half watt resistors and can be purchased at Radio Shack for about a dollar for a four or five pack.
    2012 RTS
    2012 RtS M5 , Stock Homemade Metallic Silver
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Fatcycledaddy View Post
    Mine stuck for a week, then came back this morning.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    May 2017
    Central Texas
    Unhappy Resistors are NOT required?
    Sorry, this is the first I heard of this new age remedy... Will the Hazard Hold solution work on all models? Or all models starting a specific year?
    I used resistor sets in the 2009 GS, it still hyperflashed.
    Dec 2016
    Somewhere USA
    I take it that the hyper flash occurs when the nanny detects something wrong such as a burned bulb, water in the electric system or a change in some electric draw.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Resistors
    I had to go with resistors after trying "the fix" a number of times. The resistors work and fix the hyper flash ---- period.
    For me---- hyper flash causes-------------- Kaos
    2014 RTS , Circuit Yellow
    Jul 2016
    Kamloops B.C.
    I have also had to resort to resistors, although i was hoping today was the day to install, didn't happen. Can I ask where you mounted them so they were attached to metal??
    Thanks
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Mar 2015
    Thumbs up I didn't
    Thanks
    Ray
    I attached a piece of 16 ga. aluminum to the resistor ( about 1" x 2.5" ) It's just a heat sink. Its been a year since I did this and NO problems.
    Kaos
    Jul 2016
    Kamloops B.C.
    Thanks Kaos, good idea....
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    May 2017
    Central Texas
    Default Resistors F & R
    Thanks
    Ray
    Front Resistors on the GS were behind the instrument cluster, on top of the frame end piece. Ground was to the frame, behind the bars, under the lobster Tupperware. Rear were on L brackets I put behind the battery. These brackets held the run-turn-brake module, & resistors. I used one group resistor front, one back, much easier than one each corner.
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Matahead View Post
    I only got 2 resistors, one for each direction... you put 4 on? what was the value?? mine are 6.8K at 50W
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    May 2017
    Central Texas
    Default Zero value. . .
    Ray
    I had one front, one rear. 4.5k didn't work, completely. They slowed, but not normal.
