Results 1 to 10 of 10
    Bossier LoUiSiAna
    Default Chrome auto body tape?
    So looking to add some shine & my service mechanic shared a pic another customer did to bumpskid before installimage.jpg kinda what im looking for but cant seem to find quality tape i can find pin stripe &accent tape but so far only like 2"wide looking for wider id rather trim to fit than have layers that will peel any hints?? Thx
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2016
    Parma, Idaho
    Default Chrome Auto Body Tape
    I came across a 1990's era Firebird with the six cylinder engine. In order to spice it up, the owner had added chrome auto tape to the black exterior door handles, and to the rocker panels. The car looked as tacky as can be imagined. But perhaps your Spyder will be an exception.
    Linden, CA
    Rivco makes a very nice real chrome bumper
    for your RT
    Jul 2014
    Mint Hill, NC
    Have you specifically checked 3M products? I use some 3/4" plastic trim tape to anchor my SM10 to its mount and also used it to reattach one of the Spyderpops mounting blocks for my KOTTS Grills. The only thing you must do, that the instructions on the 3M tape package don't tell you, is wipe the surface(s) where you're going to put the tape with Adhesion Promoter, PN 06396. If you don't use the Adhesion Promoter the tape won't last. If you use the promoter the tape should hold well. I had to cut different pieces of tape for the SM10 mount to completely fit the whole mount.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Bossier LoUiSiAna
    for your RT
    yes they do but I have a ST & am just a redneck just trying some things
    thank you
    I can find online but rather get my hands on to view so I can better visualize my idea kinda thing, the promoter I have heard of ,have not used personally have always just used elbow grease & rubbing alcohol, let evaporate dry has worked for all my decals. The largest crosses the full width of frunk. I'm not going all out with a wrap or anything just accents to highlight a black & chrome look while keeping my flag theme prominent.
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Jul 2014
    Mint Hill, NC
    thank you
    I can find online but rather get my hands on to view so I can better visualize my idea kinda thing, the promoter I have heard of ,have not used personally have always just used elbow grease & rubbing alcohol, let evaporate dry has worked for all my decals...
    I bought my tape, actually 7/8" not 3/4", at an Advance Autoparts store It is PN 03615. Got the adhesive promoter from a second Adv Auto store because first didn't have it. The rub, pun intended, is the 3M directions say to clean and give a final rub with alcohol, and that just doesn't do the job. The dealership mounted my SM10 in the frunk atop the battery door and it wasn't long the following spring when the SM10 mount began coming off the metal mount bolted to the battery door. I cleaned off all the old tape and prepped both surfaces per the insrtuctions on the tape. When that job didn't last at all in the summer heat I called 3M and a technician told me about the adhesion promoter. I redid the job again being very scrupulous about cleaning an prepping, using denatured alcohol and then the adhesion promoter. It lasted through last summer's heat and is still firmly attached. It is a PITA that 3M doesn't tell one about it on the tape instructions. FWIW, I found a brand new exacto knife blade the best thing to make precise cuts in the tape although the stuff is so sticky right off the roll that it grabs the knife blade. I prepped the plastic SM10 mount and applied the tape to it first, trimmed the excess and then prepped the metal mounting bracket on the battery door. In your case I recommend the same approach, prep the farkle, apply the tape to it and then prep the bump skid and apply the taped farkle. You want to be very careful because you only get one shot. Mess up and you have to do it all over again at the risk of not having the tape adhere correctly a second time.
    Cognac 2014 RT-S
    You could give Pete at www.wrapmyspyder.com a call...
    He might be able to whip something up for you.
    SpyderLovers Sponsor Spyder Wraps Pete's Avatar
    Erie, PA
    Default Chrome will get you home.
    Email: pete@wrapmyspyder.com
    Toll Free: 814-450-1923
    See our latest Spyder projects here.
    If you have a project idea for your Spyder please contact us and we will do our best to help.
    Visit our Website here:www.wrapmyspyder.com
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Spyder Wraps Pete View Post
    Concerning the Chrome air dam shown for the 2014 RT in the 1st picture do you make a chrome one for the 2010-2012 RT?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Erie, PA
    No, because the Conform Chrome PVC material we use for the kit will not curve to conform on the inner part of the air dam on that year RT. Sorry about that.
