Results 1 to 19 of 19
Thread: Trailer wiring
    Apr 2010
    Arcadia, FL/Grand Rapids, OH
    Default Trailer wiring
    I have the 2014 RT and it has the dealer installed hitch and square plug. Can someone shed some light on the wiring configuration of the four wire plug? I tried searching for a diagram with no success. Thanks in advance!
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Here is a diagram of the pin out. It's just like a flat 4 connector except it's square.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Active Member OkieDoc's Avatar
    Oct 2013
    Oklahoma
    White is Ground
    Yellow is Right Brake/Turn
    Green is Left Brake/Turn
    Brown is Running Lights
    I just finished rewiring a 1990 Bushtec Turbo and replaced the 6 wire arrangement that it had
    with a 4 wire harness and LED tail/brake lights.
    Apr 2010
    Default Pin position
    Quote Originally Posted by SteveLaoyster View Post
    I am totally technically challenged. Which wire goes where on the square plug. Also, my trailer has the old fashioned bulbs, actually they are clearance lights
    ... does this make a difference?
    0 0
    0 0
    Nov 2015
    This is probably the way your plug is on the bike. As you can see the white wire goes to the pin & the other wires go to sockets.
    Going clockwise from the pin it looks like the white wire (pin) is upper right, brown is lower right, yellow is lower left and green is upper left.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2010
    Default wires
    well I matched up the wires by color and plugged it in. Not working. Checked the flat plug trailer wiring with my van and the lights work. Any ideas for a wiring dummy?
    Nov 2015
    The output of the module is fused. RFB F4. That's right fuse box fuse 4, 10 amps if your is the same as mine. I have a 16 RTS.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2010
    Default fuse
    well if you are talking fuses now you are way over my head. Don't even know where to look for fuses. I will take it to the shop tomorrow. Thanks for trying to teach an old dog new tricks.
    Nov 2015
    Quote Originally Posted by copper View Post
    Good luck. But if you want to get into it further look at your owners manual. It has a section with fuse box location and fuse location.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Apr 2010
    Default fuse
    When I was working I had a deal with the m/c shop.... they would not write speeding tickets and I would not fix bikes. Been retired sixteen years and thought I CAN DO THIS.... wrong.
    Mar 2013
    Marion, Arkansas
    Let me ask you first, what Mfg. of trailer are you trying to get to work? Also what kind of plug is currently on your trailer? Next I have to correct an earlier post by OkieDoc. The color code of the square 4 pin connector is White is ground, and its the one that is a pin, Brown is side marker lights, Yellow is Left flasher/Brake, and Green is right flasher/Brake.
    Next your trailer may have a convertor somewhere in the tongue area. This will probably have to be removed but only removed if you just got brake lights on your trailer. If you have separate turn signal lights on your trailer then the convertor will have to be keep.
    I went through this same thing a few months back. I had a Aluma Trailer with a 5 pin round connector and cut the 5 pin connector off and soldered a square 4 pin connector in its place, removed the convertor that was hidden in the tongue area. Just remember you can do this even though it seems difficult now. If you got any other questions, just ask.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jan 2017
    Vineland, NJ
    Where can I get a 4 pin square male connector to plug into the factory 4 pin female connector mounted on the factory hitch?
    Jan 2017
    Vineland, NJ
    I found a link on another post: https://www.waytekwire.com/item/3715...20IJGE61AK10S5
    I had to buy minimum quantity of 4, so I'll have extras.
    I send for free to the first to PM me.
    Member BRandRandy's Avatar
    Aug 2016
    Dalton, Ga
    I ordered mine today from Amazon. Search for 4-Way Square Molded Connector 8 Inch Male-Only 1 Min
    The problem is the shipping is more than the part. Shipping was $7.00
    BR and Randy
    Dec 2015
    Oakley Utah
    Quote Originally Posted by BRandRandy View Post
    I ordered mine today from Amazon. Search for 4-Way Square Molded Connector 8 Inch Male-Only 1 Min The problem is the shipping is more than the part. Shipping was $7.00
    This is the one I got from Amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2014 RTL Platinum
    Oct 2013
    Wood Village OR
    I once took a flat four that was on a trailer, split it down the middle and glued it together then put a heat shrink tube on it and it matched my square four on the bike perfectly, I had some photos but cant find them now, but it only took less than an hour for the epoxy to dry and the entire process.
    2014 RTL , Black Currant
    Dec 2016
    Long Beach | Indio, CA
    Post
    I did the same thing and also used https://www.amazon.com/CURT-58050-4-...lug+%26+Socket to make the pigtail, it worked perfect...
    2015 RT LTD-Black: Belt Guard, SS Radiator Mesh & knott Grilles, Doc's Vib Damper, BS Mirrors, TricLED H-Lights, Brake & Mirror Turn Signals, FOBO, SpyderPops Bumpskid & LEDs, BajaRon Sway Bar & Billet Links, Lidlox, ISCI Hand Brake, Dual USB outlets, RamMounts, X Grip, Fuzeblock, Shortie Antenna, Alarm, Merlot's Mirror Magnets, Radar/Laser Detection, NBV Gripper Pegs, Shorty Windshield, Nautilus Horn, Gremlin Bell, Dig Clock & Voltmeter, GoPro, Nomad trailer & BRP Hitch, KradelLock, AirHawk R.
    Aug 2015
    Cleveland, GA
    Just to bring my experience with seeking a ready-made 4-pin flat to 4-pin square adapter, some have mentioned that any good auto parts store should have one.
    I went to the big three (Auto Zone, Advance, and O'Reilley's) here in Cleveland, GA, and Tractor Supply. No one had one or even seemed capable of ordering one.
    That 4-pin square guy just isn't frequently used in the automotive world.
    LaMonster has one for about $23.
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    Dec 2015
    Oakley Utah
    Quote Originally Posted by motoswami View Post
    I made my own using this and a 4 flat https://www.amazon.com/Hopkins-47975.../dp/B004BE60ZU
    2014 RTL Platinum
