Results 1 to 13 of 13
Thread: Fun with tires
    Active Member ingramsail's Avatar
    Aug 2012
    Oklahoma City, Okla.
    Default Fun with tires
    Ordered 2 federal 165/55r15 online, UPS had them here Monday on time. The best plans go down hill from there. I Had plan ahead ,had the tires off and wheel weights cleaned off of the rims. Now it's time to reorder and try again.
    Nov 2012
    North Las Vegas, NV
    Ok now I get it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Wouldn't be surprised if you get the other pair that matches this pair! Care to let us know where you are getting them from?
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Don't you put the wider one on the side that turns in the direction you use most?
    Aug 2012
    First set was sent by amazon, they have already picked up and refunded all cost. Second set was ordered from Tire Easy.com, order was made on Tues. Are to be here Friday.
    Question has anyone install the Federal Formosa AZo1, are they directional. The first set I received had inside stamped on one side and outside on other.
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    Quote Originally Posted by ingramsail View Post
    just installed those yesterday. I did not see any writing on the tires or any arrows.
    2015 RT Limited Intense Red Pearl
    Feb 2012
    Spring City,Utah
    "These are asymmeytric tyres, with the most stable part of the tread on the outer margins for reasonable cornering response in the dry, but are not directional. This is a big help when time comes to rotating your tyres, as you can swap them into any position (not just front to rear)." Product Review http://www.productreview.com.au/p/federal-formoza-az01.html
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default NEW TYRES
    I just ordered two new Federal Formosa's yesterday from E-bay, they should be In next week, 165-55-15.
    I hope they match when they come In..
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    They are not directional BUT they DO have an "outside" to them and are clearly marked.
    Chuck
    Sep 2014
    USA
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    They are marked "inside" and "outside". It's a test for the kid who mounts them at the tire shop!
    2020 RT Limited , Marsala Red
    Sep 2011
    North Plains, Oregon
    One thing I found out to do about tires is look on other websites for the tire you want and then go to Amazon to see if they have
    the same tire. then get it from Amazon. they have free Shipping. that will save you money. some site charge as much for shipping
    as the tire cost.
    Aug 2016
    Nashville, GA
    Default FEDERAL TIRES on front of RT Limited
    Please be sure to look at your new tires, there is a small arrow showing you the inside and outside on the side of the tires. My local tire store installed one of mine correctly, and one side incorrectly! Had trouble with the ride, and notice the inside arrow showing on the outside right tire! Took it to another tire store, and they reverse the tire, and it made a hugh difference in the ride and steering!! Very small arrow, so make sure to get your tires correctly mounted and balanced!! The belts must be designed to run one way!
