My data from tread depth measurements on front Kendra tires at 16696 miles
OK people.......decided last nite to see how much "real" rubber is left on my original Kenda front tires, before worrying about replacing them prior to our 1500 mile vacation in 2 weeks. Attached (if I did this "pasteing" right) are the results - which, even though I check this regularly, REALLY surprised me. Anybody.......What do you think? Again, the question for me is obviously safety, but also running out of tread and getting a flat in "nowhere'sville".
For me, I don't need "better handling" like some seem to insist on as a reason for swapping to other brands - but that's not the question here. Looking at MY results, it would seem 25-30,000 miles on these tires is doable. Please folks.....not looking for a fight on tires here, just thoughts on what I found.
all thoughtful inputs appreciated.
2014 Can Am Spyder RT Limited |
Original Kenda Front Tires - Measurements - 06/14/17 7:00PM |
Notes: |
* 16,696 miles on odometer |
* Both tires measured a 70.5" circumference - Tire Pressure 18PSI |
* All depth measurements taken at the 6 locations identified with a triangle on the tire sidewall. |
* All depth measurements were taken at 4 places across the tire, i.e., Outer groove, Outer Middle groove, Inside Middle groove, Inside groove. |
* All measurements in 32nds of an inch using tread gage. |
Outer |
Outer Mid |
Inner Mid |
Inner |
Left Tire Triangles |
1 |
7.5 |
7.5 |
7.5 |
6 |
2 |
7.5 |
7.5 |
7.5 |
6 |
3 |
7.5 |
7.5 |
7.5 |
6 |
4 |
7.5 |
7.5 |
7.5 |
6 |
5 |
7.5 |
7.5 |
7.5 |
6 |
6 |
7.5 |
7.5 |
7.5 |
6 |
Right Tire Triangles |
1 |
7 |
7 |
7 |
7 |
2 |
7 |
7.5 |
7.5 |
7 |
3 |
7 |
7 |
7 |
7 |
4 |
7 |
7 |
7 |
7 |
5 |
7 |
7 |
7 |
7 |
6 |
7 |
7 |
7 |
6 |
your measurements
I wish you had posted BASE numbers to make this easy ..... However if I'm reading your amounts correctly you have nothing to worry about .... personally I detest Kenda's for a lot of reasons ..... but I'm also practical and wouldn't change them ( for car tires ) until they were worn out ........ They appear to be wearing pretty even , which tells me your alignment is good ...... Poor Alignment will wear Kenda's out sooner than Car tires ( in my experience ). I have heard from others here about Kenda's on the front getting as much as 30,000 miles , as long as the alignment was very good ....... Mike
Front Tire Longevity
Originally Posted by teninospyder
OK people.......decided last nite to see how much "real" rubber is left on my original Kenda front tires, before worrying about replacing them prior to our 1500 mile vacation in 2 weeks. Attached (if I did this "pasteing" right) are the results - which, even though I check this regularly, REALLY surprised me. Anybody.......What do you think? Again, the question for me is obviously safety, but also running out of tread and getting a flat in "nowhere'sville". For me, I don't need "better handling" like some seem to insist on as a reason for swapping to other brands - but that's not the question here. Looking at MY results, it would seem 25-30,000 miles on these tires is doable. Please folks.....not looking for a fight on tires here, just thoughts on what I found. all thoughtful inputs appreciated.
Thanks for this. I also don't want to enter the infamous "best tire" debate. You have done an amazing job of data collection. The front Kenda's on my 2014 ST Limited are now j-u-s-t on the verge of being at the end of their life cycle. With almost 38,000 kms (23,600 miles) I feel they have done me well. My two-wheel motorcycle friends feel they are fortunate if they can achieve 28,000 kms (17,000 miles). Thanks again for your post!
Thanks for your reply !
tread depth measurment
Enjoy your planned trip, lots of tread. If something happens it won't be because your tires are worn out.
2018 F3-T
Looks good...
i am one of those getting over 30,000 miles on the fronts (Kendas) and am currently on the second set. I also got 20,000 on the rear tire and am currently on the Third tire but am trying the Arachnid tire to see how they hold up. This is what it looks like when your down to the wear limit..
20160324_085157.jpg good thing it never rains in Southern California... but never had a problem
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Mike,
I wrestled for a long time with what I was doing wrong in my measuring the other day, and whether or not they were accurate, but I can't see anything. I even told my wife "if I was 1/2 a mm off....how bad could the overall results be ??? I also noticed, after I sent my earlier response to you, that I had doubled up in words on my description of my "earlier measurement technique. Here is what I meant to say.
When I first started keeping track of the tread depths on each wheel (actually only out of "wondering"), I only did 1 row of 4 horizontal measurements "going directly across the tire" in a random spot on the circumference. Back then...Each time I measured....it could have been a totally different spot on the tire from the prior one - I don't know. My checks were random in timing, maybe a few months apart over fall, winter, spring, and more "monthly" in good riding weather or after a vacation trip.
Anyway - I don't expect 100,000 miles, but 25-30,000 or so would be awfully nice :-))
Yikes !!!! And I worry about the "wear indicators" getting close !! Obviously "the FORCE" is with you and yours :-)) Must not be any broken bottles or things on your routes either huh ?? Thanks for the picture.
I replaced my rear tire two weeks ago with a Yokohama. On one side of the original Kenda the tread was still quite away from the tread wear indicators. But if you rotated the tire 180° the tire was as smooth as a spanked babies' butt! Very poor performance from the rear tire. The fronts, however, are wearing evenly at 14000 miles and look like they will make another 10000 or so.
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
MEASUREMENTS
Mike,
Your second sentence " if I was 1/2 a mm off " ... your tire tread gauge is ( probably ) SAE = inch ..... and you had said it only changed 1/32 in 12,000 +/- miles .......this does not compute to 25 to 30,000 miles ....... but it's moot ..... your getting good miles off that tire ..... Mike ...........PS your left inside wear - indicates slight alignment adjustment needed
