Results 1 to 10 of 10
    Aug 2016
    indiana
    Default possible clutch issues?
    went to Lexington motorsports to have 2 new tires put on and get a laser alignment done,also got bike serviced.everything went well.tech took bike out for test ride came back and said clutch was not working properly in the lower rpm range.told me it needed to be adjusted or replaced with the newer style.worked fine for me,i have a 2010 rt-s se-5 with 9800 miles.just wondering if this is something to be concerned about,i rode today and see no problem.thanks for your input.by the way,$100.00 an hour labor rate.
    Default Interesting. ...
    From the mileage and model it would be strange the clutch would be going unless it has been run at very low rpm's. Those clutches need to be above 3,400 rpm to be fully engaged. Running under that would wear the clutch out prematurely. If the clutch were bad you would notice the rpm get higher but the spyder does not go faster. If burnt you would smell it. If it is ryding the same as always for you keep on going. If in doubt have some one else check it out...
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    I wonder if the tech knows that he shouldn't be shifting until at least 4000 rpm?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    My B.S. meter is starting to quiver... could this technician be just trying to sell and expensive clutch replacement, to the owner of a bike with eight riding seasons on it?
    Very Active Member cognaccruiser's Avatar
    Dec 2013
    South Okanagan, BC, Canada
    I agree it sounds a little fishy. If you didn't notice anything then I would just keep riding it as you have been. If it was starting to fail, I think you will notice. Perhaps as suggested by Ann, he was shifting at too low an RPM for your setup. Maybe he is more used to the newer 1330's and was shifting it too soon. He did say he noticed it at lower RPM.
    Gary
    States visited by Bike
    Default CLUTCHE WEAR
    Somebody correct this info if wrong ..... A dealer can provide a printout of the shift History of the transmission ??? ... if so it would be interesting to know if it was abused or shifted improperly...... jmho .... Mike
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default what part indiana !
    Quote Originally Posted by RKS-RTS-10 View Post
    wondering what part of Indiana , must be close enough too ride too Lexington ? or trailer it ..... I would ride it until it really showed some sort of different shifting pattern , but also in the mean time ---- start saving money in case { clark county Indiana here }
    Nov 2013
    Central Texas
    Somebody correct this info if wrong ..... A dealer can provide a printout of the shift History of the transmission ??? ... if so it would be interesting to know if was abused ...... jmho .... Mike
    Yes they can. They've done it on mine.
    x2 The printout will verify the rpm shifting history of the vehicle. I have never been provided with one by my dealer, but Joe and Ann showed me the information when they did our alignments.
    Aug 2016
    indiana
    Quote Originally Posted by youngers View Post
    hey youngers I'm from west Harrison,indiana Dearborn county,rode bike to Lexington and back,about 110 miles one way.never really noticed anything.thanks randy
