Results 1 to 11 of 11
Thread: jacking point
    Dec 2015
    Columbus OH
    Default jacking point
    OK, all you who have replaced your front tires yourself, I'd like your advice. My 2014 RT-SE6 has 23,000 on my Kenda fronts, so it's time to replace them. The plan is to take the old wheels and tires into my local tire dealer where he'll remove the old and install the new (going with Khumo Solus KH16 175/55/15). The thing is, I don't know where to position the two-rail jack I have to safely raise the trike in order to remove the front wheels. Is there a specific jacking point, or am I OK sliding the rails under from the side at about the center of mass?
    Jake
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I jack mine from the side directly on the main frame rail under the center of the bike. just be sure you don't jack against the premuffler/cat converter.
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    Try this.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Dec 2015
    Columbus OH
    Thanks guys, and nice touch with the pics, that'll help.
    Mar 2017
    Star, Idaho
    Quote Originally Posted by Bensonoid View Post
    Try this.
    Is that the Craftsman jack? If so how do you like it? I think I have been looking at that one.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Recently at the Pittbull Spyderfest in Springfield, I had a couple of lights installed so spent some time on the floor of the hall watching the goings on. I noted the folks from Spyderpops had the Craftsman jack and they simply ran it in from the front and heaved it up. Didn't seem to affect anything. On that recommendation, I bought the aluminum ATV jack sold by Craftsman, just shy of 2 bills (we have 11% sales tax). And I've lifted the bike with no ill effect. I got down and looked across under the middle. My cat delete pipe does hang a bit lower than the frame. Don't want to mess that alignment up. But, maybe that's just MY bike. Maybe take a really good look at what's hangin' and do what's best for you. I'm just sayin', I really like the jack. I saw a simUlar jack at Harbor Freight where cheap is King. Didn't like the finish. And I trust Sears more. Just because something 'looks' the same.......
    May 2014
    Benson, NY
    Quote Originally Posted by Ramg66 View Post
    I really like it. I struggled with a regular floor jack for a while when I first got the spyder. I should have gotten the Craftsman right away.
    Sena 20s
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    Quote Originally Posted by ricford View Post
    Be vey careful, I personally wouldn't lift from the frunk. At the very least get under the crossmember where the bottom of the frunk bolts in. But with an ATV/Cycle jack I would lift from the center frame if possible.
    Eyes can be deceiving, when I looked under I said the same thing, the exhaust pipe hangs below the frame. So I took a short piece of 2x4 to simulate the rail on the jack and lo and behold the pipe is about an 1/8" higher than the frame so jack would be fine. It was an optical illusion of sorts. You may want to check yours and ensure its below.
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    Dec 2015
    Oakley Utah
    Try this.
    Thanks for the pics.
    2014 RTL Platinum
    Northern Kalifornia
    Default Oop's
    If you jack your spyder up under the center of the frame and then remove the two front wheels and tires you will quickly change the center of gravity.
    May 2017
    Mesa, Arid-Zone-A
    I have the Harbor Freight jack and it works good for me when lifting the entire bike. When I needed to just lift just the front tires, I used my regular old 2 ton floor jack under the outside of the A arms. Did one wheel at a time and 2 wheels stayed on the ground for stability. Easy and uncomplicated.....
    Semper Fi
