Bump Skid installation disaster
Nothing wrong with Spyderpops bump skid......
Went to install the skid this morning on my new F3T. Went to drill the first hole on the right side and must have had two things go wrong. 1. I think my 1/4" bit was dull and 2. Even using a right hand drill I had the bit cocked just enough to punch through the plastic and nick the bottom of a fin on the right side radiator. $326 and wait til Tuesday to get a new radiator.
Simple simple project and I've been a mechanic all my life so I have no excuses. Just a word to the wise.
Pat
Oh that sucks! I hope to put on a bumpskid on my F3 this weekend. I'll be extra careful. Thanks.
Just use a good sharp bit and stay vertical Julie.
Bummer...
Happens to the best of us...did learn to put a depth stop on bits when doing this kind of work but not without doing what you did first to learn....
2012 RS sm5
Thanks for the reminder!
Installing one next week for a buddy...
SpyderLovers Sponsor
Boy I would not have admitted to that in a thousand years.....
Pat
So, you HAVE done similar boner things...
13 ST Limited F/R suspension, Corbin, GIVI top case
16 Vespa Primavera 150: Stock
16 Piaggio BV350: Suspension, braking mods in work
14 HD XL1200T: F/R suspension and brake mods; Corbin saddle and bags
09 Aprilia SC250: F/R suspension and minor brake mods
97 Honda PC800: F/R wheels, F/R suspension, and F/R brake Mods; Corbin saddle
90 CB-1: In work, long term project
89 Honda NT650: F/R suspension; Corbin saddle
Pat
I'm not understanding. If you put a small nick in the fin, it shouldn't affect the performance of the radiator significantly.
Did you mean you nicked a tube and caused a leak ?
IBA #47122
2020 RT Limited Asphalt Grey
Just nicked the bottom of one tube. Radiator shop will have it fixed Monday for $36. Doesn't matter how long you've been doing this sort of thing Murphy is always waiting in the weeds.
Honestly, I fail to see the need for a bump skid. After over 4,000 miles on my F3, I haven't bumped anything or skid on anything.
John F.
Tallahassee, FL
2015 Spyder F3 SE6, black
BRP Driver/passenger Footboards
BRP Adjustable Passenger Backrest
Blue Ridge Windshield
MRA X-Creen Tour, clear, clamp-on
H4 LED Headlights
F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
Easy Brackets
Leatherworks, Inc. 120 Special Slight Angle Saddlebags
Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
2-up rear shock
Idler pulley kit
Really? I hit the nose on the driveway of the gas station the second time we had ours out.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I guess I'm lucky. Unless, it's plug and play, I don't want it. I'd rather not take the chance of drilling into my radiator, hoses or any other stuff. But that's just me.
John F.
Tallahassee, FL
H4 LED Headlights
Easy Brackets
2-up rear shock
Idler pulley kit
I hope you realize that you've completely jinxed yourself with that statement!
When you do touch down (and you will!); the reasons for them will become all-to apparent!
Nah, I knocked on wood. Have a good day.
John F.
Tallahassee, FL
H4 LED Headlights
Easy Brackets
2-up rear shock
Idler pulley kit
Stuff happens
Glad you got it repaired. Radiator shops have been fixing leaks forever.
Everyone needs a bumpskid. Debris, curbs, potholes, whatever. It happens. Ann is a skilled rider. The car in front of her straddled a car starter, in the road. Median to her left, a car to her right, she swerved as much as she could. The starter's sharp mounting edges put a gouge in the bumpskid that would have split her crankcase, had she not had it. As it was, it spun, and shredded her rear tire sidewall! I'm convinced Spyderpops bumpskid saved her motor. We see plenty of evidence of the bumpskid doing it's job. The piece just works. Why risk it?
Joe Meyer
Let me include Armadillo's !
How old would you be if you didn't know how old you were?
Sorry to hear hope you get it sorted out soon.
Live, Love, and Ride! God Bless!
Whatever you do don't skip the drilling of these holes. Because a bumpskid installed without the holes in the frame will cause you more trouble than not having a bumpskid at all.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Famous last words, you just put the HEX on your ryde.
Cruzr Joe
Just starting install. I have mounted the skid plate with the alignment bolts. Looking at the holes that are supposed to be drilled into the frame it seems they are outside the centre frame rail? It is hard to tell with the pan on if the frame sort of "T's" out? Also is the pan difficult to remove? I noticed there is a bolt or other fastner inside the pan rattling in there :-(
You need to remove the bottom covers so you can see what you are drilling. A screw and a few push pins on each one.
