Thanks Thanks:  6
Likes Likes:  9
Results 1 to 9 of 9
    Member tjmonty32's Avatar
    May 2016
    columbus, ohio
    Cool 1 year maintenance report
    I purchased my used 2012 Spyder RT A&C in May 2016 with 30k miles. In the last 12 months I have replaced the battery (original finally died), replaced the antenna (broken in a wind storm). I added two rear speakers to improve the sound, and due to getting hit by a car I have replaced the rear fender. None of these were really complicated. I just reached 34k miles and I am preparing to do my first oil change. Also according to the previous maintenance record I am going to replace the brake pads. I am lucky that I have a mechanical background, yet nothing has seemed to complicated (except the battery location). In my opinion the Spyder is not very complicated to work on.
    2012 RT A&C, 2 Rear Speakers, Chrome Upgrades, Tri-Axis Handle Bars, Corbin Custom Leather Seat,
    Kurykan Iso Handle Bars, Driver floorboards and foot pegs.
    Active Member quasi's Avatar
    Oct 2015
    morgantown west virginia
    Nope, not to difficult. that is until it's time to remove the airfilter box to access the spark plugs. haven't changed out the plugs yet but will soon. and when I do the airbox and resonator are going into file 13 and JT's airfilter will be installed. actually the worse thing about doing basic maintenance on these rascals is removing the Tupperware.
    man can't live on air alone
    2012 RT-S SM5
    United States Navy Veteran 28feb74/28aug81+ 2yrs active reserves
    RM2 2318/Communications Systems Tech Control Operator
    Default Good to Hear.....
    Looks like you have enjoyed your ryde, outside of the accident glad it was only a fender....looks like a leisurely mornings work and then out to seat the brakes and enjoy a ryde...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2016
    columbus, ohio
    it is my hope to most of the maintenance myself.
    May 2016
    columbus, ohio
    luv it
    Consumer Advocate akspyderman's Avatar
    Chugiak, Alaska
    and The 2012 A & C is a pretty good machine. We have the same in 2011 flavor. Oil changes, filters, tires and check overs are all we have encountered so far. 25K on the clock.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow)
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 9 years, 133,000 miles, 5 Spyder miles per post.
    Feb 2012
    Spring City,Utah
    I have a 2012 RT L that has needed only wear items and oil changes. These are all easy to do,only time consuming because of all the body panels that need to be removed. This can be a little complicated and there is a definite order to that removal.
    Great machine. I bought mine with 8500 mi on it and it now has 28000. Should put another 8-10000 on it this year.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    Venture Riders
    TOI
    Aug 2012
    Central Coast, CA
    Check the pads before actually buying replacements, if you haven't done so already. (You post kinda read like you were replacing on a schedule and not out of need.) If you are buying brake pads I recommend the EBC pads vs. OEM. The EBC are much better quality than OEM and usually cheaper to boot.
    2014 RT SE6
    Previously 2008 GS SM5
    2016 BMW R1200GSW
    2002 DRZ-400S
    Oct 2011
    Kalamazoo, Mi
    Default one year maintenance report
    Congratulations on your purchase; that is a beauty for sure. Have you purchased a shop manual??? If not the green manuals can be purchased online and work fairly well. mostly wear and tear stuff that goes out on these machines and the wrenching is mostly straight forward. The suggestion below about the brakes is good; BajaRon is a great supplier of most things spyder; and if he doesn't have it Spyder pops most likely will!! Enjoy your ride, doing your own wrenching is the best way to learn about the intricacies of your ride IMHO. Just rolled over 40K on mine last month.
    2014 RS SM 5
    My mods: trailer hitch, outlets for GPS and I-touch to listen to music with. Mad Stad 22 in touring windshield, clear protective wrap on side panels and behind steering head, neoprene grip cushions, Bead rider seat cushion, Smooth Spyder backrest, Day Long seat, Time out trailer, Garmin 660.
