Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Quote Originally Posted by Deer Slayer View Post
    Reasons not to go. Looks like here?
    That's a pretty sad reason. With that reasoning, I guess you never travel outside the US. Too bad, you don't know what your missing.
  2. #27
    Active Member SteveP's Avatar
    Mar 2016
    Toronto
    Default Original containers only
    Quote Originally Posted by JKMSPYDER View Post
    I have two prescription drugs and several supplements I take daily. When I travel I usually put them in ziplock bags to save space rather than bringing the containers. Will I have any trouble getting into Canada if I have them in ziplock bags?
    You might get lucky and not get searched .... but if they find a " baggy " with pills in it you could be in for a long delay . If they are narcotics or opiates or antidepressants etc you could be in legal trouble and/or denied entry
  3. #28
    Idaho
    According to Canadian customs rules they must be in the original container with a label that clearly describes the dosage. Also, although this probably won't concern anyone going to Homecoming, you may not take more than what is required for the prescription period, if that is like 10 days or whatever, and in any case no more than 90 days supply. A list showing the prescriptions from the doc is advisable, but not required. There is no requirement to have a copy of the actual prescription from your doc, contrary to many travel suggestions I've read. That is harder and harder to get since so much is being done electronically. My doc refused to be bothered to fill out a hand signed scrip.
    2014 Copper RTS
  4. #29
    Idaho
    Quote Originally Posted by PrairieSpyder View Post
    Last night I went through the process of sorting my meds into little zip-lock bags for each day. But I'll also bring my collection of bottles, in case I have to prove what they are. I take six in the morning and four at night, so just using the bottles is cumbersome. So I like to pre-sort them.
    To be safe, just in case you are unlucky enough to be scrutinized, put them back in the bottles. Rules are rules. See my post above. If the customs folks want to ignore them you're safe, but if they want to enforce the rules, you could be SOL.
    2014 Copper RTS
  5. #30
    Active Member MurrayBrown's Avatar
    May 2016
    Winnipeg, Manitoba, CANADA
    Default PRESCRIPTION drugs in Canada
    You won't have a problem. This assumes that the label on the prescription drug container shows the name of the drugstore, hopefully the name of the doctor, and the contents.
    Never an issue internationally for me; you won't have an issue coming into Canada.
    Enjoy your stay in Canada!
    2014 ST Limited
  6. #31
    Idaho
    You will if you get inspected thoroughly. Leave them in the original pharmacy containers. Don't tempt fate.
    2014 Copper RTS
