Results 1 to 6 of 6
    Sep 2016
    Lewiston , Maine USA
    Default Noise from rear?
    I have a 2012 rt and on a recent ride I noticed on some small bumps & pot holes( Can't miss all of them) I have a rattle coming from the lower rear of my Spyder. New to the Spyder World so I was wondering if there's something in the rear axle or sprocket or wheel/tire I should check or have checked by dealer? Thanks
    It it's a rattle: something is obviously not as tight as it should be...
    The only thing that you can do: perform a meticulous search of the components, and see what needs to be tightened -up.
    Good luck; please let us know what you find!
    Default Agree...
    There were some that have the leveling arem loose on the RT's with air ryde. You could check on the left side of the swingarm and see it all is well there. If yours does not have the system then the search will have to continue...check and see if you do not have any loose items in the storage compartments...
    ​2012 RS sm5
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default NOISE
    YA, ME TOO, i had noise coming from behind......
    so i told the wife to stay home...
    Aug 2007
    Greeneville, TN
    Be sure your license plate is secure.
