Sam's Club Now Selling Trailers?
saw this trailer today at Sam's Club. priced cheap if you need a trailer.
says it's 6'4 inside x 10'
https://www.samsclub.com/sams/karava...rod20301097.ip
2015 RT Limited Intense Red Pearl
How much? Im not a member but im still curious
try getting a title for it. Read some of the feedback.
find the store manager and I am sure someone would sign off on it. if not then return it ... pretty simple
QUALITY TRAILERS
I looked at that trailer at my local SC. Might not bad for a occasional use trailer.
My thoughts.
The hinges and latches on the fold down rails are skimpy, and your defiantly not going to tie down your load to those rails without doing damage.
The gate needs more supports. That expanded metal isn't as strong as you think. It will sag if your running something heavy up that gate frequently. The gate takes the most abuse on a trailer if your using it for a 4wheeler, UTV, ect.
I've rebuilt the gates on every trailer I've owned because they just don't hold up.
Now, I use my trailers everyday from spring to fall, and I can guarantee you that gate wouldn't last a week taking one of my mowers on and off several times a day.
So, for occasional use, maybe. But add some bracing to that gate. I'd still buy from a reputable trailer dealer long before I'd recommend this trailer.
THE KARAVAN IN QUESTION
My thoughts.
OK, Now we have some hands on ...eye's on .... knowledge ........ I only saw a Pic and what was in the desc. which I said was minimal ..... But I have seen other Karavan trailers ...mostly Snow-mobile and Boat type and I thought they were well made and sturdy ........... maybe they have gone el-cheapo ....... Thanks for the heads -up ...... Mike
The SC trailer is a "utility" trailer, like someone said, for intermittent use - like landscapers, etc. But I've used a similar steel trailer to haul a Spyder. You'd tie down to the frame, not the rails.
Before I bought my Aluma 7210 trailer, I looked at some similar aluminum utility trailers at big-box home improvement stores. They were similarly priced. So I'm not sure this one is that much a bargain. At least not around here.
I agree karavan is well known for there snowmobile trailers.
That's what we used for towing our sleds: the bearings never lasted an entire season.
Have run their boat trailers before, never an issue.
