Results 1 to 14 of 14
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Default 2014 RT A Arm Grease Fittings
    Seen a post on SpyderLovers a few days ago concerning A Arm Grease Fittings.
    I've always done my own maintenance and though I had looked in the past never seen any A Arm Grease Fittings on my 2014 RT Ltd.
    After reading the post about the fittings had to check again!
    My service manual has then clearly depicted in the manual but went in search of them and them are not on this model. (see attached pic)
    Does anyone know if BRP switched to a sealed bearing on this model?
    Thanks for any input!
    2014 RT-Ltd , Cognac
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Default 2014 RT A Arms
    I just have a lowly RS but I believe that 2013 was the last year for non sealed bearings; mine does not have any zerks
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Oct 2013
    rome new york
    Quote Originally Posted by IGETAROUND View Post
    HE IS CORRECT!
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    I did a search for you looking for grease fittings.
    According to JCThorne ... Starting with the 2014 RT, these bushings no longer have greasefittings and are maintiance free.
    2015 RT Limited Intense Red Pearl
    Jul 2010
    Las Vegas, NV
    Default Yep
    Got the 14, did the same search. None!
    Joe Meyer
    Question: Has anybody taken a "non-zerk" bike, and "re-zerked" it?
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default ZERK-JERK
    anyone that has performed their own service on the pre-14 will tell you that whomever decided to put 'straight-up' fittings in, has to be a ZERK-JERK.... absolute bear to inject grease into those... on my '09 RS, i R&R mine with 45 deg fittings... i'm so happy that BRP decided to eliminate those things and install 'no service' joints instead....
    Dan P
    SPYD3R
    May 2013
    Thanks guys!
    For a minute there I was afraid I was going to have to use some of my Farkle money on a new pair of glasses!!!
    Quote Originally Posted by Purple Guy View Post
    Thanks guys!
    These are cheap enough...
    Feb 2012
    Spring City,Utah
    The question was asked if someone had zerked a non zerk bike My question is just the opposite. Does anybody know if the maintenance free bushings can be put into a pre 2014 Spyder?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2013
    Stanton, ca
    My understanding is no.
    They changed some dimensions that wont allow them to fit without changing the entire A-arm assembly.
    Bob
    2011 RT-S SM5 - Black
    Feb 2012
    Spring City,Utah
    Thanks Bob. You have come to the aid of us DIY'ers so many times. Always on the ball.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Feb 2015
    Carson City, NV
    Default GREASE ZERKS
    So I go to grease my 2013 RTL last summer and figure out you need to be a triple jointed monkey to get the job done. Soooo, being pretty smart (ha ha), I decided to change the zerks to 45 degrees, gonna be easier, right?? I go get the zerks and get about half way home and get to thinking......are the holes American or metric?? Are my freshly stolen from a Peterbilt shop zerks gonna fit the metric holes? Are they gonna work out at the first bump?? Chickened out, did not change them. Maybe this summer.....
    Bob, k7xi. 2013 RTL
    SoFlo
    My experience while installing Fox Shox on our 2014 RTS indicates the front suspension arms pivot on molded rubber bushings. Same type they use in a car front end or car rear suspension.
    Most often these have an inner crush sleeve to allow the bolts to be fully tightened without crushing the frame or suspension arm. The outside utilizes a metal shell that is pressed in to the suspension arm.
    Between these two metal parts, they mold rubber that flexes and allows the suspension arm to move up and down. while the rubber flexes to give rotation, it is also slightly compliant allowing a smoother ride.
    Typically maintenace free until the rubber degrades, which is often many many years.
