Results 1 to 10 of 10
    Aug 2016
    Kentucky
    Default Adding Oil Between Changes
    2013 RT-S. How much oil is needed to bring the level up to full from the "add" line?
    Thanks
    Bob
    Old Crow
    1960 Vespa 150
    1965 Bridgestone 175
    2003 Kawasaki 1600 Classic
    2010 Kawasaki 1700 Nomad
    2013 Spyder RT-S (Current ride)
    Bossier LoUiSiAna
    There is no actual measurement I can offer just add a lil at a time & keep checking till you hit your mark.(try have a suction device like turkey baster handy if you go over) I have learned about regular engines, if you've noticed other dipsticks have the hash marks on end of dipstick. Those equal 1qt of oil per that engine. Just take your time & try lil shot or double shots at a time. If way low maybe 1/4 qt,give time to settle, follow manual instructions for run time & check again Repeat as needed.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jul 2011
    Mitchell, Ontario, Canada
    From the add line ( bottom of the dipstick) to the full line, is 500 ml. So that is 1/2 quart/liter. So if checked regularly, while hot not cold. When the oil goes below the add line. Add half a quart and the oil level will be between the add and full, perfect. If you check the oil level cold. You will overfill it.
    2018 F3 LIMITED
    Nov 2012
    North Las Vegas, NV
    When we had the 2012 RT I just kept the oil between add and full. Usually added about 2 oz. at a time.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Hard to say...
    would depend on where your oil level is when you check it. The add a little at a time and coming close but not to the full mark is the best way. How and where you ryde will determin how much you need to add. The consumption will lessen as the engine gets more mileage on it. Then there is the type and brand of oil...use the best you can get and check it after long rydes....
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    Just be sure the oil is HOT! If the oil is not at operating temperature you're very likely to get a "Low" reading. Then when you add you're likely to have an 'Over Fill' situation which may lead to "burning" more oil than you might otherwise.
    Apr 2017
    North Central Florida
    I was surprised to see that the procedure for checking the oil is VERY SPECIFIC for the 998 models.......so be sure you are doing it right.
    Quote Originally Posted by Easy Rider View Post
    This ain't your Granddaddy's Oldsmobile.
    Dry sump engines require very specific procedures.
    Aug 2016
    Kentucky
    I'm following procedure when checking level. Usually when I get home after a ride.
    Bob
    Old Crow
    1960 Vespa 150
    Jul 2014
    Mint Hill, NC
    As Billy said, here's the information from pg 128 of your operator's manual.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
