want to install stebel horn on 2016
RTS
dumb question where is the stock horn?
Is it under the heat shield on left side?
stebel horn installed....very loud stebel 11690019 twin tone 137 db
Originally Posted by marty1096
RTS
very pleased...the panel is the panel closest to the left light...not the 2nd big panel over...
Upgrading the horn is easy. The Stebal will mount where the stock horn is located.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
At a local rally, I had a vendor install a Stebal horn. He said it did not need a relay. It was not louder than my OEM....I installed a relay and it helped a little but it sure is not what I expected from a Stebal....Marty, is there different models of Stebals? What do you have. Thanks.
I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
SAVE THE CHUPACABRA
If you have not been to Luckenbach, your journey is not complete.
I installed a Stebel on on 2015 RTL in the location of the oem horn, and it was significantly louder. I used the relay because it prevents overloading the horn button which may cause premature failure. The horn button isn't cheap to replace, but the relay is.
model 11690019 Stebel air horn includes the relay...you need the relay
[QUOTE=Mr. Cognac;1259080]
relay is needed to keep from burning up your horn's on off switch. the Stebel comes with a 30 amp relay however i suggest you get the universal harness easier to wire and it has a 40 amp relay included. It is 137 db. I just had my rear tire replaced and the guys were impressed with how loud my horn was. lol https://www.amazon.com/Stebel-116900...r_t_automotive
https://www.amazon.com/Universal-Plu...4AKM45TR5YD0V9
I used a 4 inch L bracket to mount it. bent the bracket a little to fit...
Here is a link to a thread I started. It has pictures of my install.
http://www.spyderlovers.com/forums/s...78#post1244978
Horn is on the left side. You'll see it as soon as you take the first cover off. Good luck.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
