Results 1 to 22 of 22
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default annoying beeping when parking
    I'm a little perplexed, I've tried a bunch of different ways and it seems like the Spyder beeps at me when I come to stop-----
    Here's the way I do it
    Foot on brake
    Shift to neutral
    press parking break
    Turn key off and pull out
    I do this every time, sometimes it works , sometimes it doesn't, does anyone else have this issue.....is the procedure wrong, I have 1250 miles on my new Spyder and it seems to be random whether it beeps or not
    Please advise
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Nov 2012
    North Las Vegas, NV
    They usually only beep if the park brake isn't engaged. Give it a few more seconds to engage before you shut off the key.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Just wait like he said
    Jun 2013
    queens ny
    stupid question, have you looked to see if it is a car beeping at you,,,,, sorry i just had to ask
    NO BIKE AT THIS TIME
    Oct 2015
    Iowa
    I'll try waiting a few more seconds , I'll repost it it helps
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Bossier LoUiSiAna
    Quote Originally Posted by Kredab View Post
    That will help there is also the indicator light on dash If it's not on & blinking Thinks the P brake is off & will fuss at you If it is as random as you say there can be a problem with the indicator switch or wires, worth looking into. If you have the electric Pbrake
    fyi should be under the side panel center of bike just above foot rest on RH side when on bike(same as brake on rear tire or "throttle side") will also be good time to inspect your cable & how well it rolls on the cam
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Quit parking next to Telephone Company trucks that are in reverse!
    Seriously: Make sure that the parking brake indicator on your main screen is happily blinking, before shutting things down...
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Not related to the beep (thread police, back down!) but I don't think shifting to neutral serves any purpose. The bike will automatically be in neutral when you start it up.
    If you shift to reverse and turn the bike on, the backup lights will stay on until the bike is started.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Whether you shift into neutral, or decide to leave the bike in gear: the key is to develop a routine that you can follow.
    Dec 2013
    Quote Originally Posted by OverHillAndDale View Post
    ..... The bike will automatically be in neutral when you start it up....
    But if you leave an SE in gear when you shut it down, surely it won't let you start the engine unless your foot is on the brake pedal??
    That's what mine does anyway.
    So it DOES help to select neutral & apply the park brake before shutting it down! That way, when I go to ryde it next I can do the pre-ryde check, then put the key in & turn it on while standing alongside my Spyder & then begin the jacket, helmet, gloves routine, doing the mode thing (after I've re-read the Safety Card, of course!! ) as & when it allows, and then actually start the engine up & let it idle for a bit while I complete the rest of the jacket, helmet, gloves routine... and all that happens before I actually climb aboard!
    You can't do that if you don't leave it parked in neutral!
    Mar 2015
    Goose Creek, SC
    Thumbs up GeorgeL
    when I got my 2012 RT LTD I also had a problem with the break not engaging. Was shutting down to fast when I slowed down I would feel the break pedal push back. If I rush I will get the beep. Feel for the push.
    good luck
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    [QUOTE=OverHillAndDale;1257908]Not related to the beep (thread police, back down!) but I don't think shifting to neutral serves any purpose. The bike will automatically be in neutral when you start it up.
    Yes Spyder will find neutral on it's own at start up. The REASON for hitting neutral before shut down, is it allows you to start
    without your foot on the brake. Rare is the time I let it find neutral on it's own.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Active Member Ramg66's Avatar
    Mar 2017
    Star, Idaho
    You must have a bit of a delay, I turn my park brake on and wait till it blinks then put in neutral and turn off. But when I accidently forget Park Brake it beeps I turn key on press brake and turn off almost instantly and no beep.
    2016 Can Am Spyder RT-S SE6
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    My 2014 RT-s will beep when the retained power finally shuts down. I don't think there is any real reason for it. It just does it. It is also easy to not notice this if you are distracted by any other activity. Anything.
    Oct 2015
    Iowa
    Default Update - randomly
    Just to let you know, I dropped the Spyder off at my dealer before going on family vacation. Week and a half later -NO update.
    They can get the Spyder to beep randomly on shutdown but can't find anything wrong. They are a Platinum dealer, they should know what they are doing. As soon as they open tomorrow I will find out what is going on and give u update
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Oct 2015
    Iowa
    Default Beeping update
    Just to bring you up to date. 16 Rt-s went to dealer for 1.5 weeks, readjusted parking brake motor, better but still about 1 every 10 times-still beep. Dealer contacted BRP
    Got Spyder back rode about 1000 more miles , dealer called BRP sent a new motor, dropped Spyder off today, should get it back early next week. Dealer has been great......
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default My experience
    I have had this happen a couple of times now, the first time I was getting gas when I went to the leave the brake disengaged how ever the light remained on I drove home parked the bike felt the brake engage. turn the key off and it would beep I tried turning it off and nothing got off the bike it beeped for a few mins then stop did not happen again till yesterday I took a video of I'm going to see a dealer as I think the switch may be having issues.
    Foot on brake
    Shift to neutral
    press parking break
    Please advise
    Oct 2015
    Iowa
    Default Beeping
    Quote Originally Posted by Chasinsparks View Post
    Keep us posted. My dealer has been great . They are replacing the motor now , sounds like BRP isn't sure what it is, I'm guessing if the motor doesn't do it they will do the switch next. I'll post when I get it back
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    May 2010
    Knob Noster, MO.
    Default Every one is wrong
    Everyone has it wrong...... It is your Spyder telling you it does not want to stop
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Oct 2015
    Iowa
    Default BEEPING UPDATE
    Got "Purl" back from the dealer today. BRP sent a new parking brake motor. So far it worked -no beeping out of place. Also the little noise that you hear when it is engageing sounds different, sounds stronger, more definite, mine sounded weak. A shoutout to my local Dealer in Waterloo,Iowa "Dr Powersports " they took care of me. They are building a huge new building . When they get it done they want to make it a place for people to visit ( maybe a new Spyder Event coming, hopefully I can talk him into it). If you start having random beeping, now you have a place to start.....Now if this weather can cool off a bit , I can put some miles on
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    Tgsts good news! No one wants to have a weak sounding parking brake. Good news also on your dealer, if you organize an event we will definitely be there.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
